Question about Internet Computers & Internet
How do I access Internet Explorer 10 from myitlab
danoyachtcap
    Top Expert:
  • Internet Master
  • 2,907 Answers
I don't think you can unless your tablet is made by Windows.
If you're running windows 7, just press the icon that looks like a letter e....or says "Internet Explorer"
Hope this helps.
Posted on Mar 03, 2015
How to get a free access code for myitlab
Hello Friend::::
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jan 17, 2013 | Cell Phones
How to open restricted web sites by administrator
Launch Internet Explorer. Find whether the website you are trying to access is on the restricted websites list.
Remove the restriction by clicking "Remove" and then click "Close" and "OK."
Open the "Tools" menu and then select "Internet Options." Next select the "Security tab" and then "Sites.
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favourites Tools and Help
Select the site that needs to be unblocked.
You may choose multiple websites at a time.
Refresh the page by hitting the refresh icon shown in the Internet Explorer or simply Press F5 in your keyboard. You should now be able to access restricted websites.
Blocking Websites on Windows XP
Access the "Tools" menu and then go to "Internet Options." Click on the "Security tab," and then click "Sites." Next, click "Add."
Type in the URL of the website you wish to block. You may type in more than one web address at a time.
Click "Close" and then "OK" once you have typed in the websites you wish to block. Refresh the page by hitting the refresh icon shown in the Internet Explorer or simply Press F5 in your keyboard.
Hope this helps
Oct 04, 2012 | Nokia IP 350 Firewall
I need to enable Active X to run so that I can do myitlab . I don't know how to find my browsers.
Click on 'Tools'
Select 'Internet Options...'
Select 'Security' tab.
Select Internet in Web content zone.
Then, click on 'Custom Level...'
Go through all the ActiveX setting there, select 'Prompt' or 'Enable'. Select 'Enable'
hope this helps
If this helps you resolve your problem, please
consider giving me a good rating and a quick
"thanks" or "good job".It will help me as well.
Thank you.
Oct 28, 2010 | Microsoft Internet Explorer 7
Links using internet explorer 8 will not open, facebook, farmville, live mail...
This is possibly due to the phising filter in the IE 8, to resolve this issue follow the below steps.
Add the facebook.com in to trusted sites loaction, and disabling the add ons in the browser.
1) Check for your internet security settings, or activex or java settings
2)you may try to access the links, without any add-on's to verify if it works fine.
Click the Start button,
Click All Programs and click Accessories
Cclick System Tools, and then click Internet Explorer (No Add-ons).
Verify if it works fine and if it works, here's what you can do:
Disable it. If an add-on causes repeated problems, disable it by using Add-on Manager in Internet Explorer.
Report it. When prompted, you might want to report the problem to Microsoft. The report is anonymous and requires nothing from you except your permission. These reports are used to improve our products and to encourage other companies to update and improve theirs.
3) You may also try to optimize Internet explorer on your computer and later verify if you are able to access the links.
Access the link below and follow the steps to optimize Internet explorer.
http://support.microsoft.com/kb/936213
4) If the issue persists, you may try to reset the internet Explorer settings on your computer and verify if you are able to fix the issue.
To Reset Internet Explorer Settings feature, follow these steps:
1. Exit all programs, including Internet Explorer (if it is running).
2. Type the following command in the Start Search box, and then press ENTER:
inetcpl.cpl
The Internet Options dialog box appears.
3. Click the Advanced tab.
4. Under Reset Internet Explorer settings, click Reset. Then click Reset again.
5. When Internet Explorer finishes resetting the settings, click Close in the Reset Internet Explorer Settings dialog box.
6. Start Internet Explorer again.
Access the link below to know more about resetting Internet Explorer:
http://support.microsoft.com/kb/923737
Oct 10, 2010 | Microsoft Internet Explorer 8
When using my D-Link-655 router, I can't access some Web sites, but I can access others. This applies to all computers on my network. I can, for example, access my work (company internal) websites and use...
Have you isolated the problem by directly plugging your computer directly to your modem, bypassing your router? If you have done this but still cannot browse some websites, then this is a DNS problem with your Internet Provider. Try using Open DNS, 208.67.220.220 as Primary and 208.67.222.222 as secondary. Then try to browse again. But if you have plugged directly to the modem and was able to access those websites, then there is a restriction on your router and you may need to press and hold the reset button to reset it back to factory defaults.
Sep 10, 2010 | D-Link DIR-655 Wireless Router
Yahoo messenger automatically shut down
Please upgrade first the version of your Windows Internet Explorer. The connection of Yahoo Messenger rely on Internet Explorer.
If you are using different web browser like Mozilla Firefox, It doesn't matter. Just install Internet Explorer 8 compatible with your operating system and do not default it as your browser.
Do this and you will find it easy to access your yahoo Messenger in just a second.
Here is the link for downloading Internet Explorer version 8. Select the operating system you are currently use.http://www.microsoft.com/windows/internet-explorer/worldwide-sites.aspx
After installing the IE8 and Yahoo Messenger 10, restart your computer.
Please comeback after establishing your Yahoo Messenger connection and give me some rating.
Thank You for using Fixya.
Jun 05, 2010 | Yahoo Messenger
My Yahoo Messenger keeps shutting down after I
Hi!
I have problem like that before and here is what I did...and it works, until now i can easily access my yahoo messenger..
I am using a mozilla browser.. because it surfs fast....the yahoo messenger can't be accessed.. with the right username and password and the net connection is stable..but no luck to get log in..I did uninstalled and reinstalled yahoo messenger for several times but still it won't work..
Then I search internet and found out that yahoo products rely its connection on microsoft Internet Explorer.....meaning yahoo messenger is best supported by Internet Explorer....So what I did is download the latest Internet Explorer 8 and download also the yahoo mesenger 10.
It did not matter whether you will be using IE8 as your default web browser or not. Just install IE8 on your computer (mine..am still using mozilla as my default web browser)......after installing IE8, install Yahoo Messenger10....
After successful installation.. sign in at yahoo messenger and it will work...
If you want to know the link for IE8 and YM10 here it is..click this file and save it..
1. Internet Explorer version 8 free download
2. Yahoo Messenger 10 free download
I hope this help you..
thanks...much appreciated if you rate this solution..thanks.
May 30, 2010 | Yahoo Messenger
How to change router settings for BUffalo WCR-G54 wifi router? i can't access the URL: http://192.168.0.11.1 thanks!
This is actually wrong: http://192.168.0.11.1
If your router is connected to your computer via ethernet cable you will be able to get the configuration page of the router.
Windows XP
1. Click start
2. Click run
3. Type cmd in the box and press enter
4. On the black screen type ipconfig and press enter
5. Look for the default gateway
6. Copy that and use that to access the configuration page using the internet explorer
7. Open internet explorer, type http://the default gateway you copied in the address bar of the internet explorer
ex: http://192.168.1.0
Windows Vista
1. Click pearl button (start in xp)
2. Click on start search box (run in xp)
4. Right click the black icon up at the top
5. Click on run as administrator
6. Click on continue
7. On the black screen type ipconfig and press enter
8. Look for the default gateway
9. Copy that and use that to access the configuration page using the internet explorer
10. Open internet explorer, type http://the default gateway you copied in the address bar of the internet explorer
Jan 14, 2010 | Buffalo Technology WHR-G54S Wireless...
When i sign to my FB it signs in but comes ( cannot show the page
reconnect your internet. It's either that or facebook server was being updated/down.
Reconnect your internet and try in 10 minutes.
Jun 10, 2009 | Facebook Social Network
Computers & Internet Logo
 Grubhead
Grubhead
Geoff
Sharps s
