Question about Rheem RQPMA037JK R410A All-in-One Package Unit Heat Pump
WHAT IS THE BTU CAPACITY OF THE AHR42C3XH21B?
Vincent Schnittert
    New Friend:
  • 40 Answers
42 would be a 3.5 ton
I’m happy to help further over the phone at https://www.6ya.com/expert/vincent_f7b7c5f4dedd2565
Posted on Mar 03, 2015
What is m6x06f2a btu output?
Features
  • Cooling Capacity (BTU) : 6,000 BTU
  • Maximum Cooling Amps : 5.6 Amps
  • Maximum Cooling Watts : 618 Watts
  • Heating Capacity (BTU) : 0 BTU
  • Maximum Heating Amps : 0 Amps
  • Energy Efficiency Rating : 9.7
  • PTAC : No
  • Window Type :Standard
Aug 04, 2015 | Maytag M6Q10F2A Air Conditioner
Can my 1999 Cadillac Seville concourse overheat by mixing too much water with antifreeze??
Theoretically yes. Antifreeze has a higher heat capacity than water. Basically, a liter of antifreeze can hold more heat than a liter of water. I dont think it would be enough to cause an overheat though
May 20, 2015 | 1999 Cadillac Seville
How many BTU's?
British themal units : BTU: the indicative units describe the cooling capacity of the Airconditioner. So please check tables to see your capacity.
May 16, 2011 | Heating & Cooling
Whats the cooling capacity
1 ton of cooling equals 12,000 BTU
2 ton of cooling equals 24,000 BTU
3 ton of cooling equals 36,000 BTU
1000 sq ft home needs about 30,000 BTU of cooling..... if you live in Kansas USA.
This is basic cooling. Hope this helps.
Mar 26, 2011 | Heating & Cooling
Cooling capacity :18000 BTU/h Air circulation
check the amperage of the compressor if it is high better to replace.
Nov 30, 2010 | Ruud UBHC Air Conditioner
What is the cooling capacity of a 3 ton air conditioner
Hi, the cooling capacity for 3 tons of cooling is 36,000 B.T.U.'s, For every ton of cooling, you have 12,000 B.T.U's of cooling. I hope this is what you needed to know.
Good Luck,
Shastalaker7
Nov 04, 2009 | Carrier BCA101R Air Conditioner
How large a room does a 10,000 btu air conditioner cool
What size unit do I need for my room? Use the following chart to find the appropriate size air conditioner to use:
AREA TO BE COOLED / CAPACITY (BTU/HR)
100 to 150 square feet = 5,000
150 to 250 square feet = 6,000
250 to 300 square feet = 7,000
300 to 350 square feet = 8,000
350 to 400 square feet = 9,000
400 to 450 square feet = 10,000
450 to 550 square feet = 12,000
550 to 700 square feet = 14,000
700 to 1000 square feet = 18,000
If the room is heavily shaded, reduce needed capacity by 10%
If the room receives a lot of direct sun, increase needed capacity by 10%
Add 600 Btu/Hr for each person in the room if there are more than two people
If the unit is for a kitchen, increase the capacity by 4,000-6,000 Btu/Hr.
if this helps please vote me a fix ya
Jul 21, 2008 | Heating & Cooling
Rheem RQPMA037JK R410A All-in-One Package Unit Heat Pump Logo
136 people viewed this question
Top Rheem Heating & Cooling Experts
Lawrence Oravetz
ray gallant
 Russ Hill
Russ Hill
Are you a Rheem Heating and Cooling Expert? Answer questions, earn points and help others
