How do i install my ink cartridges into my epson stylus nx125
Starts on page 23.
http://files.support.epson.com/pdf/nx125_/nx125_qr.pdf
Replacing Ink Cartridges
Make sure you have a new ink cartridge before you begin. You must install new
cartridges immediately after removing the old ones.
Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are
vacuum packed to maintain reliability.
Note:
Leave the expended cartridge installed until you have obtained a replacement, or the ink
remaining in the print head nozzles may dry out.
1. Turn on your printer.
2. If an ink cartridge is expended, the error and ink lights on the control
panel stay on.
3. Open the document cover, then open the ink cover.
Caution:
Do not remove the ink cartridge guard or you may damage the printer.24 Maintaining Your Printer
4. Press the y Stop button.
If a cartridge is low or expended, the print head moves that cartridge to the
replacement position to indicate that it should be replaced. The P Power light
starts flashing.
If two or more ink cartridges are expended, the expended cartridge at the far
left moves to the replacement position. The P Power light starts flashing.
If no cartridges are low or expended, the print head does not move.
Note:
Do not hold the y Stop button for more than three seconds, or the printer may
start cleaning the print head.
5. Squeeze the tab on the cartridge and lift it up. Dispose of
it carefully. Do not take the used cartridge apart or try to
refill it.
Warning:
If ink gets on your hands, wash them thoroughly with soap
and water. If ink gets into your eyes, flush them immediately
with water. Keep ink cartridges out of the reach of children.Replacing Ink Cartridges 25
6. Before you open the new cartridge package, shake it gently four or five times.
Then remove the cartridge from the package.
Caution:
Do not touch the green chip on the front of the cartridge. This can damage the ink
cartridge.
7. Remove the yellow tape from the bottom of
the ink cartridge.
Caution:
Do not remove any other labels or seals, or ink
may leak.
8. Insert the new ink cartridge into the holder
and push it down until it clicks into place.
9. Press the y Stop button. If another cartridge is low or expended, it moves to
the replacement position. Repeat steps 5 through 8 to replace any other
cartridges that need to be replaced.
When you press the y Stop button and no other cartridges need to be
replaced, the print head moves to its home position and the printer starts
priming the ink. This takes about 1 1/2 minutes.26 Maintaining Your Printer
When the P Power light stops flashing and the error and ink lights go
out, ink charging is finished.
10. Close the ink cover, then close the document cover.
Caution:
Never turn off the your Epson printer while ink is charging or you'll waste ink. If the
error and ink lights remain on after the print head moves into its home
position, an ink cartridge may not be installed properly. Press the y Stop button
again, and then press the ink cartridge down securely.
Note:
If you replaced a cartridge while copying a document or photo, cancel printing and
make sure your original is still placed correctly on the document table. Then copy
your original again.
If you remove a low or expended ink cartridge, you cannot reinstall and use the
cartridge.
