Question about Apple iPod nano
Ipod frozen on language screen
I tried to restore, reset, format, etc. my 2 gb ipod still boots to the language screen and won't go any further.
Posted by skinnyguy on
  • 7 more comments
  • brentdoss Nov 16, 2007
    me too
  • juleshippy Nov 16, 2007
    My ipod is also frozen on the language screen. It has the locked button on, even if I switch the hold switch back and forth. It will not move from the language screen. I tried to reset, but it won't do anything. Any help appreciated
  • denisesunny Nov 21, 2007
    Exactly same problem. Toggle hold on and off press menu and centre buttons, get apple logo but then goes back to frozen language screen.
    Hope someone can help.
    Denise
  • Anonymous Nov 27, 2007
    Ditto
  • Edward45 Nov 27, 2007
    Ditto
  • JUMBO1 Nov 30, 2007
    Same problem can anyone help?
  • spsmith37 Dec 04, 2007
    Same problem on my 20 GB click wheel. Someone Please help!
  • hobjrde Jun 30, 2008
    exactly the same problem with my Ipod classic
  • Anonymous Jul 05, 2008
    screen frozen
spsmith37
I have been reading other posts and supposedly the problem with the language screen is that the link inside the ipod for the lock button has come unhooked and needs to be hooked back. I will post the link so you can read about it for yourself. I think this means you have to open up your ipod. Read some of the posts in this website for more info. No official word on fixing the problem. Just suggestions. http://www.command-tab.com/2006/03/31/fixing-a-frozen-ipod/
Posted on Dec 04, 2007
My screen is on language selection and does not let me scroll or anything i think its frozen.
If your iPod is frozen or won't turn on, the steps to reset it vary by model.
  1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
  2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
  3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
  4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
  5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
  6. Try putting the iPod into disk mode.
    • While in disk mode, connect the iPod to iTunes and try to restore.
    • If the iPod is still not recognized by iTunes, the iPod should be serviced.
    Hope i helped you.
Thanks.
Aug 06, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
My ipod nano is stuck on language selection and is frozen can you help me?
    Hope i helped you.
Thanks.
I cAN SCROOL DOWN BUT IS STUCK ON THE LANUAGE SCREEN
If your iPod is simply stuck on the wrong language, then the best way of resolving your issue will be to restore the iPod using iTunes. If it is in the correct language but stuck on the language screen I would reset it. I posted a step by step on both just to be sure I got you all the information you need. If this does not resolve your issue, please do let me know.
Learning how to reset or restart your iPod:
Article: HT1320 Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
How to restore iPod
(ARTICLE NUMBER HT1339) Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software.
The 4 possible restore options are: Restore Option
1: Restore - Restores with same iPod Software version already on iPod. Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option
3: Use Newest Version - Restores with the latest iPod Software available. Restore Option
4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
May 05, 2009 | Apple iPod nano 3rd Generation
Ipod in chinese dont know how to switch back to english.
If you accidentally set iPod nano to use a language you don’t understand
You can reset the language.
1 Press and hold Menu until the main menu appears.
2 Choose the sixth menu item (Settings).
3 Choose the last menu item (Reset Settings).
4 Choose the first item (Reset) and select a language.
Other iPod nano settings, such as song repeat, are also reset.
Note: If you added or removed items from the iPod nano main menu (see “Adding or
Removing Items on the Main Menu” on page 11) the Settings menu item may be in a
different place. If you can’t find the Reset Settings menu item, you can restore
iPod nano to its original state and choose a language. See “Updating and Restoring
iPod Software” on page 69.
Good Luck and Please Rate FixYa!
Jan 18, 2009 | Apple iPod nano
Ipod touch 1st gen locked keypad chinese language
I can help.plug in and boot computer.In my computer click on the ipod and format.After format, open itunes it will recognize it and reinstall needed files.load music and again enjoy your ipod. Confused or need further help?contact me.thanks for using FixYa.please vote.RICHARDM69
Jan 10, 2009 | Apple iPod touch
Frozen on language screen
Do the 5 R's:
These are for Nano, but they apply to all iPods:
Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with your iPod nano. If
one of the following doesn’t help, read on for solutions to specific problems.
â Reset your iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer and make sure you have the latest software updates
installed.
â Reinstall iPod and iTunes software from the latest versions on the web.
â Restore your iPod nano. See “Updating and Restoring iPod Software” on page whatever.
Jun 16, 2008 | Apple iPod nano
About ipod shuffle
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
The restore is the last one, if you get a error message let me know!
http://www.apple.com/support/ipod/five_rs/
Good luck.
Jan 07, 2008 | Apple iPod shuffle Second Gen. Silver (1...
you have to hold the the menu and middle ong for 10-20-30 secs
hold the menu +center button and it will turn off and reset
Nov 24, 2007 | Apple iPod nano
Apple iPod nano Logo
5,960 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Sean Cole
Sean Cole
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
