HP Envy 4500 e-All-In-One Printer, Copier, Scanner Logo
A
Anonymous Posted on Mar 03, 2015
How do I change size of photo that I want to print from my tablet
Keith Brown
Level 3:
  • Master 604 Answers
  • Posted on Mar 03, 2015
Keith Brown
Master
Level 3:
Answers
604
Questions
Helped
152355
Points
1823
The size of your print is a function of the software you use to edit and prepare your photo. If you just want to print the photo as is, the size is a function of the printer software. When you click print a box should open with some choices, including the choices for the photo. If you have the instruction manual for your printer, look for the page(s) that describe the photo printing options. Hope this helps.
What size photo do I use for emai?
You can use any size, it really depends what you want to do with it. If it for a website or something like facebook then a low rez pict will be fine. You want to make a print out of it then high resolution. Sure remember the higher the quality the larger the size (data storage, no physical size of picture)
I uploaded photos from my samsung tablet at a walgreens kiosk and pressed prints and enlargements I wanted to enlarge them to an 11 by 14 which I did before without a problem the photos now are cut off on...
Hi, You need to go into your printers properties to change the sizes.
If you have your manual read how this is done. If I was there I could do this for you. Good luck.
Photos are not printing to correct size
May i know the model # of the printer.
You can also try this. When you click on Print button and the window pop up - Click on printing preference and check the Size of paper in the Advance/feature tab.
If you find any other size you dont want, set it to the correct size you want it to print.
IF you want to make these changes permanently, Click on START Button and click on Control panel and open Printers folder - Highlight the printer icon and right click on it and click on printing preferences and change the paper type.
Regards,
Suhail
When I copy to photo paper it reduces automatically, why
Print on special and custom-sized media
To print on special or custom-sized media (Windows)
1. Load the appropriate media. For more information, see Load media.
2. With a document open, click Print on the File menu, and then click Setup,
Properties, or Preferences.
3. Click the Paper/Features tab.
4. Select the media size from the Size is drop-down list.
To set a custom media size:
a. Click the Custom button.
b. Type a name for the new custom size.
c. In the Width and Height boxes, type the dimensions, and then click Save.
d. Click OK twice to close the properties or preferences dialog box. Open the
dialog box again.
e. Select the new custom size.
5. To select the media type:
a. Click More in the Type is drop-down list.
b. Click the desired media type, and then click OK.
6. Select the media source from the Source is drop-down list.
7. Change any other settings, and then click OK.
8. Print your document.
To print on special or custom-sized media (Mac OS)
2. On the File menu, click Page Setup.
Chapter 2
28 Use the device
3. Verify that the correct printer is selected.
4. Select the media size.
5. To set a custom media size:
a. Click Manage Custom Sizes in the Paper Size pull-down menu.
b. Click New and type a name for the size in the Paper Size Name box.
c. In the Width and Height boxes, type the dimensions and set the margins, if
desired.
d. Click Done or OK, and then click Save.
6. On the File menu, click Page Setup, and then select the new custom size.
7. Click OK.
8. On the File menu, click Print.
9. Open the Paper Handling panel.
10. Under Destination Paper Size, click the Scale to fit paper size button, and then
select the customized paper size.
11. Change any other desired settings, and then click OK or Print.
Print borderless
Borderless printing lets you print to the edges of certain media types and a range of
standard media sizes.
NOTE: Open the file in a software application and assign the image size. Make
sure the size corresponds to the media size on which you are printing the image.
You can also gain access to this feature from the Printing Shortcuts tab. Open
the printer driver, select the Printing Shortcuts tab, and select the printing
shortcut for this print job drop-down list.
NOTE: Borderless printing is not supported on plain media.
To print a borderless document (Windows)
2. Open the file that you want to print.
3. From the application, open the print driver:
a. Click File, and then click Print.
b. Click Properties or Setup.
4. Click the Paper/Quality tab.
5. Select the media size from the Size is drop-down list.
6. Select the Borderless Printing check box.
7. Select the media source from the Source is drop-down list.
8. Select the media type from the Type is drop-down list.
Print borderless 29
9. If you are printing photos, select Best from the Print Quality drop-down list.
Alternatively, select Maximum dpi, which provides up to 4800 x 1200 optimized
dpi* for optimum print quality.
*Up to 4800 x 1200 optimized dpi for color printing and 1200 input dpi. This setting
might temporarily use a large amount of hard disk space (400 MB or more) and will
print more slowly.
10. Change any other print settings, and then click OK.
11. Print the document.
12. If you printed on photo media with a tear-off tab, remove the tab to make the
document completely borderless.
Change settings from an application for current jobs (Windows)
To change the settings
1. Open the document that you want to print.
2. On the File menu, click Print, and then click Setup, Properties, or Preferences.
(Specific options may vary depending on the application that you are using.)
3. Change the settings that you want, and then click OK, Print, or a similar command.
Change default settings for all future jobs (Windows)
1. Click Start, point to Settings, and then click Printers or Printers and Faxes.
- Or -
Click Start, click Control Panel, and then double-click Printers.
2. Right-click the printer icon, and then click Properties, Document Defaults, or
Printing Preferences.
3. Change the settings that you want, and then click OK.
9. If you are printing photos, select Best from the Quality drop-down list.
dpi*.
print more slowly.
10. Select the media source. If you are printing on thick or photo media, select the
manual feed option.
11. Change any other print settings, and then click Print.
How do i go about printing different size of photos? they are all different sizes.
There are two basic ways to change the print size of your photos/documents.
1. You can go to file/print or you can press cntrl + p on your keyboard. the print menu will come up. go to properties/features. when it opens, look for resizing options. Under resizing options you will see print at actual size and scale to paper size. Select scale to paper size and list box will activated. Select the paper size to scale to from the list. If you are not familiar with paper sizes then this list introduction should do. The conventional official paper size is A4, half of that is A5, and half of that is A6.
2. other procedure is to right click on the photo/image and select print. a print wizard will pop up. it will ask you to chose size of images.
Good luck,
Ryan
Printing 4x6 photos with photosmart express - prints only 4x5 image on 4x6 paper
Hi
the photo printing settings will need to be changed on the PC to either the correct paper size or change the paper size to match the size of the print out
27helpful
2answers
My HP C7200 printer won't print from the photo tray
If you using a mac: After choosing the Photosmart C7200 to print your file on the print preview, change PAPER SIZE to 4x6, then lower down, change from PREVIEW to PAPER TYPE/QUALITY, more options will open underneath, on SOURCE, change from MAIN TRAY to PHOTO TRAY. You should also change the PAPER TYPE to some kind of PHOTO PAPER (whichever one your using, but the standard seems to be HP ADVANCED PHOTO PAPER)
Printer will not print on 4 x 6 photo paper
It looks like the settings have been instable. I suggest you to reinstall the printer and the software provided along with..
Thankyou
Lexmark Z53 prints photos on 'normal' but enlongates image on 'best'
I'm getting around the problem by using Windows or Nero print options to get the photo as near to the size I need. It would be good if I could print photo's from Photo studio though much simpler and less time consuming.
k24674
Grand Canyon Tech
Grand Canyon Tech
