Question about Lexmark X5470 All-In-One InkJet Printer
How to find 6500 pin number
Lexmark 6500 printer scan pin number
Posted by don silva on
5 Related Answers
Stephina37
  • 3 Answers
SOURCE: where do i get a
Go to the Lexmark Imaging icon (located on the taskbar) and look to the left and down the bottom. You will see Network Settings, click on the "view or change network settings." When you get in, uncheck the "I WISH TO REQUIRE A PIN TO SCAN TO MY COMPUTER" and then press OK. This will remove the pin setting from your scanner. Lexmark technical support just did that for me, now my printer does not ask for a pin number.
Posted on Mar 30, 2009
printmastert
Lexmark
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: how to find the PIN number to scan for a Lexmark
    Unless you have setup a PIN for scanning when you installed the printer the default PIN is 0000. If you setup a pin and don't remember, go to the Lexmark Productivity Studio, click on setup and diagnose printer, then on left side select Advanced, another screen will pop up click on Networking and another screen will appaer at the bottom there is a link that reads Change your PC name and PIN for network scanning, click there and you should be able to see and/or change the PIN.
    Good Luck and don't forget to rate this answer.
    Posted on Mar 02, 2010
    paulyrussell
    Pauly Kendrick
    SOURCE: Lexmark, scanner asks for pin code and won't scan without it.
    This drove me mad for about 2 hours (I've just experienced the same problem), but have finally found the solution!
    Firstly, it depends on what Lexmark you have (as different printers use different software)...
    For my Lexmark which is an S600, I went into the program 'Lexmark home' which was in the lexmark folder on the start menu and in my lexmark software folder, went to 'settings' and then 'Network computer name'. From here you can set the pin.
    According to people experiencing this problem with other Lexmarks, you can do this via the equivalent 'productivity suite' program through 'network settings'.
    Hope this helps.
    Posted on Oct 02, 2010
    puertobori
    • 7733 Answers
    SOURCE: My Lexmark 6500 Series AIO Printer just started
    Run the Clean Print Nozzles test
      1. Go to the Lexmark Control Program/Solution Center and run the Clean Print Nozzle test. The colors you should see are:
        - black, if a black cartridge is installed
        - yellow, magenta (a reddish purple) and cyan (a dark sky-blue), if the color cartridge is installed. NOTE: The colors may be different if a photo cartridge is installed.
      2. Observe the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right, with no gaps.
      3. If there are gaps in the lines, run the Clean Print Nozzle page a few more times to try and clear up the issue, or try the cleaning ("wicking") procedure below to conserve ink.
      4. If the page is faded from left to right and the cleaning procedure does not clear up the issue, the cartridge is probably out of ink. Replace the cartridge.
    Clean the cartridges
      1. Remove the cartridges from the printer following the instructions in the printer's User's Guide.
      2. Take a warm, damp paper towel and fold it so that it has about 4 to 6-ply thickness.
      3. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are touching the towel. (The nozzles are where the ink comes out of the cartridge.) Hold the cartridge in this position for about 15 seconds.
      4. Now drag the cartridge lightly across the paper towel in one direction only (left to right) until the bottom of the cartridge looks clean.
      5. Install the cartridges following the instructions in the User's Guide. IMPORTANT! Make sure you select Old cartridge. Failure to do so could reset the ink levels, as explained above.
      6. Repeat the nozzle cleaning procedure one more time.
      7. The diagonal lines should now be solid. If not, contact the Lexmark Technical Support Center by e-mail and describe the results of this test.
    Posted on Dec 10, 2010
    virginiarobi
    • 713 Answers
    SOURCE: Does the lexmark x4650 have scanning features, if
    you dont need to enter a pin number go to devices and printer right click print and trouble shoot it.
    Posted on Feb 16, 2011
    When ask to scan to computer lexmark printer asks for pin
    If you haven't setup a PIN for scanning, try to update your printer driver. Please visit the Lexmark website at http://bit.ly/iofMNC to download the driver. Execute the file to update your existing printer driver.
    Jul 27, 2011 | Lexmark X4650 InkJet Printer
    How to find the PIN number to scan for a Lexmark X4650
    Feb 22, 2010 | Lexmark X4650 InkJet Printer
    Scanning/copying problem (Lexmark 6500 series x6575)
    please just you scan the object to resuleasion in and dp is 600 to 12oo select and you scane object and aply print is dark is ok.
    Sep 17, 2009 | Lexmark X5150 All-In-One InkJet Printer
    Hope this helps.
    May 17, 2009 | Lexmark X6650 4-In-One Wireless InkJet...
    Lexmark x4550 wireless scanner pin code
    PLease I need one password because i want to scan some documents and i miss the manual.
    best regards
    Oct 05, 2008 | Lexmark X4550 InkJet Printer
    I own a Lexmark 6500 series and I am not able to figure out how to scan. It's asking me for a pin number. Please help :(
    You can initiate a scan from your computer using the producstivity suite, you don't need to do it from the printer itself.
    Aug 31, 2008 | Office Equipment & Supplies
    Where do i get a pin number for my lexmark X4530 i would like to scan something plz thanks
    Jul 21, 2008 | Lexmark Office Equipment & Supplies
    Lexmark X5470 All-In-One InkJet Printer Logo
    138 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Muntejaya Ginting
    Muntejaya Ginting
    CheckitRight
    CheckitRight
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
