I have a Simpson eziset 950 and I have no idea what its doing.
It goes though wash cycle but when it get's to spin , drain it drains but no spin and the pump keep draining it flashes sp . Please help
It could be many things. It the load is large and heavy, the machine electronics won't allow fast spin if the load is not even and even the slightest wobble will stop higher spin speeds. Here are a few things you can try. Split the load into two or three and then do rinse and spin.
Other possibilities are a slipping belt due to the weight, or the speed processor on the motor.
Always disconnect power & turn off water before doing any work. This is the simple fix for Error code E20 Simple fix to this problem with out having to buy another controller board. Carefully remove back cover & Make a lite adjustment to the electronic pressure sensor turn with Philips driver 45 deg clockwise to raise water level by 25mm will fix the pump running all the time & will spin now.
That sounds like the pump is jammed. Have you checked for hair slides or similar? Once the pump is free to operate, your Simpson should resume normal service.
Possible that the motor has failed and it has developed a leak to the body which seems to be felt over the machine, Isolate the motor and test the external voltage presence.. if absent it can be related to the motor.
