Question about Huawei Cell Phones
When I am listening to music on my Huawei Y536A1 through headphones, every so often the music stops eor about 5 to 10 secs and then starts up again. Ive tried changing a few different settings and nothing works. I have the google play music player, could that be the problem? any help is appreciated. Thanx
Posted by Andy Persson on
Joe m
    New Friend:
Have the same phone and d same prob. Tried downloading other music players from Google play store with no success. Finally settled on shuttle music player with no success. I noticed that the problem happened after the screen for the music player and the phone went to sleep to conserve the battery. I went into the settings for shuttle music player and changed the screen settings to never sleep or lock. I went into the phone settings and changed those screen settings to not lock for the maximum time, 30 minutes. Since doing that, I have had no problems with music player. Frustration has ended. Here's hoping you still have the phone, and that this works. I won't charge you 10 US dollars for this information. Good luck! :-)
Posted on Mar 10, 2016
4 Related Answers
Anonymous
SOURCE: radio cannot do loadspeaker without headphones
i think its a factory setting you cant change. you cant listen to radio without headphones.
Posted on Nov 04, 2007
Anonymous
  • 193 Answers
SOURCE: audio player music
put the music on your SD card in the Audio Folder. Copy only the music, not the folders they are in (no subfolders). once you do this, open the audio player. at the bottom left, click list, then bottom left click options. click settings. the top slot tells where it wants to look for the music from, make sure it says memory card and not phone. click ok. should be able to see options again at bottom left, if not go through the steps again i have provided. click options then add. open the audio folder this is where your music should be. click on every song you want in your playlist. when you are done, click back this will show your playlist. click back again. this will take you to the audio player. you can play the music from here now. go back to the settings tab where you chose memory card as your source and the little cd icon which is list auto gen, turn it off.
For full help topics I have a cd available for 10 us dollars. Has 100's of mp3 ring tones wallpapers, and java games and opera java browser. Guaranteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact [email protected] Pay Pal only, will send out First CLASS Mail in padded envelope. If interested I will send Pay-Pal invoice that can be filled out and returned with instructions. Guaranteed safe transaction.
Posted on May 22, 2009
Anonymous
  • 5 Answers
SOURCE: music from my dare only plays out of one headphone
To reset it just reverse what you did before it went out, example, headphones plug in and it comes out real quick now theres no sound, turn off the phone and plug the headphones back in and turn on phone with headset in 3.5mm jack then unplug after phone has fully rebooted and ready for use.Trust this works cause i ve done it a many of time since i hooked it up to my car to listen to music. ps did you know you can change the sound effects under the menu while the music is playing to different types of bass levels.
Posted on Jun 12, 2009
schatterjeem
  • 3 Answers
SOURCE: N79 freezes while accessing few application.
in memory card,---put right thing in right profile,ling songs give in sound/sample,photo--images(out side camera profile),avoid 2 use lots of application,because phone memory is low.uninstall unnecessary things.use trusted software.
Posted on Mar 27, 2010
Can I add a sim card to a Huawei Y536A1 phone
As long as it is a GSM network phone.
Dec 01, 2017 | Huawei Cell Phones
My Huawei Y536a1 puk code is locked how do I unlock it
PUK codes are only available fro your service provider .
call them on another phone, prove that you own the account and they will give it to you
May 14, 2016 | Huawei Cell Phones
Had system apk data erased on Android phone huawei y536a1 how do I replace it phone acting up
) For Android 2.3 or earlier: Enter "Settings" < "Applications" < "Development" < "USB debugging"
2) For Android 3.0 to 4.1: Enter "Settings" < "Developer options" < "USB debugging"
3) For Android 4.2 or newer: Enter "Settings" < "About Phone" < Tap "Build number" for several times until getting a note "You are under developer mode" < Back to "Settings" < "Developer options" < "USB debuggin
Feb 26, 2016 | Huawei Cell Phones
Cant listen to music it pauses all the time
best thing to do is for example this always happens to me on my iphone so always check if the connection is connected then it will start the video all over again
Mar 31, 2013 | Huawei Cell Phones
My urban beatz tempo over ear headphones won't work they play no sound at all connected to my I pod or computer it just happened out of nowhere?
I have that same problem and I need a answer but I walked in m class and the chord hit the table and it just stopped mine is about a week old also
Sep 08, 2012 | Audio Players & Recorders
I recieved a message alert while listening to my music through my headphones and the player stopped. Now the player shows its running but theres no sound.
when listening to music and alert comes through the music will always pause, so that you can check the score, read alert or whatever........ to continue music just press play........ in your case shut it off and restart (boot it up again)
Mar 29, 2011 | HTC Inspire 4G Smartphone
Hey, I have a problem with my soundsystem Logytech Z4 and I would like to know if you can help me? The following problem occurs: The black control panel, where I can adjust the volume and bass has a...
Sounds like (no pun intended) the amplifier circuit in the speaker is bad. When you use the headphone the amplifier is not used - only the preamp. It will need repair.
Nov 25, 2010 | Logitech Z4 Speakers
Cell Phones Logo
152 people viewed this question
Top Huawei Cell Phones Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
