I think i have a leak. the compressor just wont kick on. the fan works but blows only hot air. the coils are not cold to the touch either.
This is in a car or home?if car and the compressor does not engage at all or turns on for 1-2 seconds and turns off again?if it does not engage at all it is a electrical problem(s). if it cycles on off then it has no freon and can try sealer and fill.
If the compressor deosn't kick in, you ar not going to fell the cold. There are other things to prevent the compressor not kicking in. First if you suspect a leak, have it charged up with dye added, so the leak can be located for further analysis. Good luck.
it is at home. Its a window unit, goldstar R5050 model # GL5400
it's a home window unit
I found my problem, there was an electrical wire that went from the compressor to the motor that had come undone. it works great!!!!!!!!
Car or home ?
