Mth Z-4000 - 400 Watt Transformer Logo
A
Anonymous Posted on Mar 02, 2015
How do you remove the terminal screws on a MTH-4000?
Onan 4000 won't turn over
check for bad battery, loose terminals ,dirty terminals , faulty starter relay
if it is not starting check for oil level is correct ( low oil level sensor turns off ), diesel -air in system
tip
Star Trac 4000 Treadmill Deck Bushing Replacement
Replacing a Deck Bushing or Deck Stop Delrin Rod on a Star Trac 4000 TreadmillTools Needed: Phillips Screwdriver, Pliers (optional). Tools needed may vary depending on your hardware.
  1. Switch the power off on the unit.
  2. Next, unplug the unit from the wall.
  3. Loosen and remove the old deck bushings.
  4. Stubborn deck bushings can be removed with the assistance of pliers, once the screws have been loosened completely.
  5. Install the new deck bushings. (Check with mfr. for proper torque during install process.)
  6. Now, plug in and power on the unit.
Video of Replacing the Deck Bushing on Star Trac 4000 Treadmill
I cannot get my MTH engines to run properly. Power is on, bell and horn sounds, lights are on
MTH locomotives have internal batteries that may need to be replaced. The circuit boards in some older MTH locomotives can be damaged if operated with discharged or faulty batteries. Contact MTH customer service for help with your engines.
Replace worn electrical cord
Terminal block is fastened/secured with body by a screw but before removing the terminal block from body, make sure that the iron element terminals are also disconnected. this can be done by opening the screws on other side of the cord terminals-3 in number as also in the cord. Otherwise the terminal block would not come out fully.In any case you normally do not need to remove the terminal block.
Apr 05, 2012 • Tefal Irons
1helpful
Timer not working on 4000 series, think its 4014 single pole single switch for pool pump. pump turns on when manually turn switch on but timer does not move. I feel the normal resistance and can move the...
1) If circuit breaker is not tripped or shorted, then timer clock motor has probably gone bad.
2) Some places still sell paragon timers, depending on model number.
But model number given is for 240Volt timer.
3) The clock motor is not available that I can find.
Paragon is no longer making the 4000 series timers or parts
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
4) Model number given does not match wiring terminals shown in manual.
4014 is DPST 240Volt timer with 4 wiring terminals labeled 1 2 3 4.
http://waterheatertimer.org/pdf/Paragon-4000-series.pdf
5) Paragon 4000 series timer with terminals 1 2 3 is 120Volt timer.
6) Replace 120Volt timer with Intermatic T101 indoor timer or T101R outdoor timer.
Crossover wiring:
Paragon terminal 1 goes to Intermatic terminal 1
Paragon terminal 2 goes to Intermatic terminal 2
Paragon terminals 3 goes to Intermatic terminal A
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
7) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
2helpful
How do i wire a Paragon 4001-00 timer?
Link below has wiring diagrams for 4001-00 timers:
Manual with wiring diagram:
http://waterheatertimer.org/pdf/Paragon-4000-24hr-7000-7day.pdf
4001-00 is wiring diagram #1
There are 3 terminals 1 2 3
Black Hot wire from circuit breaker goes to terminal 1
Black wire to Load (light, fan, motor) goes to terminal 2
Whites wires connect to terminal 3
Maytag md 4000 dryer, removing the top?
hi thanks for the question .2 screws at the bottom of front panel remove remove front 2 3/8 screws under the top at front remove & lift top .thaks the appliance doc
Sep 28, 2008 • Dryers
3helpful
Onan 4000 RV Generator - where is the oil drain plug?
It should have a cover on the floor bottom that is held in place with two torx (star) screws. remove the cover and you can remove the plug with a 9/16 socket.
Acer ferrari 4000
There could be screws behind the battery area if you haven't found so. If it doesn't come out then you gotta remove the bezel on the top of the keyboard... might need some preying be careful plastics break easily. when you get the bezel off then you might see some screws holding the keyboard down and now remove those and be careful not to destroy and of the white ribbons they are extremely hard to replace if broken.
'87 Audi 4000 Quattro - vacuum advance problems.
On the vacuum line that operates the advance on the dizzy, there is a plastic piece that controls the upshift light, it has a two terminal connector and an adjusting screw on one side. Today I bypassed this piece, my car revs willingly past th 4000 mark and continues to build power. I assume this piece or the small hose it uses was leaking. Sweet.
Top Mth Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Mth Toy Expert? Answer questions, earn points and help others
