Amana ARB2557CSR / ARB2557CSL Bottom Freezer Refrigerator Logo
Posted on Jul 08, 2009
Refrigerator starts -runs for two weeks, compressor won't restart
Compressor starts when cold - runs well for approx two weeks, then compressor won't kick back on. buzzing/humming/ticking sound as it tries to restart
after shutting off overnight - same process repeats.
Is this a compressor or relay problem?
Anonymous
Level 1:
  • Contributor 28 Answers
  • Posted on Jul 09, 2009
Anonymous
Contributor
Level 1:
Answers
28
Questions
0
Helped
8659
Points
57
It might be but I would first check the condenser to see if it's blocked or if the condenser fan (if it has one) is not working. The "buzzing/humming/ticking" sounds you're hearing is the compressor trying to restart after it became locked down. Excessive pressures in the system or compressor overheating is usually the cause although sometimes the bearings in the compressor simply lock up.
Check to see if the fridge cycles on and off by the thermostat. If it doesn't cycle and just keeps running then the thermostat is bad and that can cause compressor failure thanks to "slugging". If it does then you want to check the defrost timer. Turn the timer's dial until it clicks into defrost and see if it comes out on its own. Check if the compressor has trouble starting after defrost. If it stays in defrost the timer is shot. If the timer times out and the compressor will not restart then the relay might be bad or, the compressor might be going bad.
A 3in1 relay/capacitor/overload might help out and give the unit a little longer time but sooner or later it will go.
Refrigerator ping noise
call a technician for a proper diagnosis
could be a problem start/run capacitor for the compressor
1helpful
Freezer won't stay cold
What is the model number of your unit?
Won,t freeze frig won,t get cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
My refrigerator is set on coldest number it won't drop below 55 my freezer isn't freezing ice cream melts, its done this twice when we have glitches in power doing a storm thaen it takes a week or...
heatman101
Compressor kicks/clicks out after approx 10 sec run time,fan runs normal,not froze up, freezer barely cools,negative frig, happened overnight to 6 yr old unit
heatman101
Compressor tries to start but won't ...odd odor when fan runs....approx 8 year old unit... will trip surge protect power strip, but not 20 amp circuit..
IT PROBABLY IS OUT OF FREON AND AS IT TRIES TO START DUE TO THE LACK OF REFRIGERANT AND OIL IN THE LINE IT SHUTS OFF OR IT COULD BE A BAD STARTING DEVICE ON THE COMPRESSOR THAT POPS THE POWER TRIP.
Refrigerator is constantly running. Temperature on both freezer and refrige seems to be normal. About a week ago, we pulled everything out of the refrigerator, turned it off for about 5 hours and...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
2answers
The refrigerator and the frezzer stop working. I have power because the lights are working normally. Can i fix it.
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
1helpful
Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
