Question about Carrier Heating & Cooling
Need wiring diagram for carrier 40yr042300 air handler in order to find common wire (c wire) for thermostat
Waqy Woo
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 79 Answers
You don't need the common for the thermostat unless you are installing a thermostat that doesn't take batteries and gets its power from the hot and needs the common to complete the circuit.
Posted on Mar 03, 2015
My goodman ac unit. M#g8x130301bd comes on with the thermostat turned off when i turn thermostat to cool the fan on the air handler wont come on
Incorrect low voltage wiring, or if the wiring is old, most likely a break in the insulation of the wiring creating a short.
First thing, check the wiring diagram to see that all wire colors are attached where they should be at the thermostat.
Then look at the wiring diagram at the air handler and verify the control wires are on the proper terminals.
Apr 05, 2016 | Goodman Heating & Cooling
Need wire diagram from T-stat to Air-Handler then cond unit
green goes to g on air-handler,white goes to w on air-handler yellow goes to outside condensor, red from air-handler goes to rh-rc on thermostat, whire off c on air-handler goes to outside condensor.
May 13, 2014 | Ruud Heating & Cooling
WIRING THE THERMOSTAT TO AC UNIT THEN FROM THE UNIT TO HANDLER
Generally, you would go from the thermostat to the air handler, and then, from the air handler to the outdoor unit. I don't know if you have a heat pump or not, so I will give you a simple diagram and you can contact me if you need more.
Thermostat : Y G R W and sometimes C
Air handler: Y G R W and C
Outdoor unit: two wires connecting to the contactor ( not heat pump)
Thermostat; Y--------------Y(air handler cooling)------------------one side of contactor, outdoor unit
G-------------G (air handler, fan)
R--------------R (air handler ,hot)
W-------------W (air handler, heat)
C--------------C (air handler, common)------------other side of contactor, outdoor unit
This is a typical wiring diagram. Just contact me if you have something different. Hope this helps. Stay cool. mark
Jul 10, 2011 | Heating & Cooling
Wiring a h/p thermostat
When dealing with the low voltage wiring, the color of the wire means nothing.
You will need to go to your air handler and determine which wires are hooked up in the unit and then correspond the same wires on the thermostat.
Wire colors are only going to help the person that originally did the wiring. For Example, I use black for common whereas others may use blue.
Jan 08, 2010 | Carrier 38CKC036 Air Conditioner
Forgot the manual to wire carrier fan coil - took care of the thermostat -but need to wire fan coil
Carrier wires are as follow Red black green whiteyellow. R common Black ground Y cool O or orange Reverse valve G fan W heat. The white on the Air handler depending on your electric backup heat has two wires together connected to white. Orange connects to orange on the condenser. Unless you have terminal board the everything is marked. Ruty
Jun 06, 2009 | Carrier Heating & Cooling
Wiring match-up
If this is a standard heat cool unit. You have a tstat with rygwcob. Just color code the wire to the unit. Some air handlers such as Rheem and carrier use different collors for there common Carrier black Rheem or Rudd Brown. Two wires that go outside use yellow blue. Yellow to Y fron Tsta and blue to common or blue,blavk or brown.or C
May 30, 2009 | Heating & Cooling
Fuse blowing on tappan air handler
most of the time its out by the ac unit . you have a shorting thermostat wire .. the outside unit has a large wire thats 240v and a small one that 24v thats the one you want to look at . look for bare wires , look where it goes into the wall , thats the common place . "critters" love to chew thermostat wire . so take a look . .....please rate this answer , i need votes . thanks
Jan 24, 2009 | Heating & Cooling
Wiring connection for a Ruud air handler & seeking its wiring diagram.
we are trying to install a goodman heat pump with a rheem air handler, the orange wire is hook up and the unit is still staying in the heat mood. does anyone have a wiring diagram for the air handler, their is some white wires in the air handler one with a purple strip and one with a black strip we need help
Jan 05, 2008 | Heating & Cooling
Wiring Diagram for Ruud Heat Pump
Unfortunately, the wiring diagrams for heat pumps are not so easy to come up with. The outdoor unit will have its own diagram, but may not include the indoor air handler and will probably not include the thermostat. That said, the orange wire is commonly run from the thermostat to the reversing valve in the outdoor unit. This wire is usually not connected to the indoor airhandler. The orange wire is usually used in a unit that has the reversing valve energized in cool. Ruud, however has its reversing valve energized in heat. Probably not useful but maybe helpful
Mike
Jan 04, 2008 | Heating & Cooling
Wiring Diagram
here is a basic wiring diagram for all air cond systems your thermostat consist of treminal r w y and c run a four conductor wire fromm thermostat to ai handler the air handler should allso have eather have red blue white wires or a teminal block marked r w c r stands for red w for white c for comon allso blue run color for color from the thermostat to ai handler with exeption of yellow yellow runs straigth to condenserand retuns in white wire to air handler wich gets conected to comon hope this help[s you
Sep 02, 2007 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
139 people viewed this question
Top Carrier Heating & Cooling Experts
Dennis Boxerman
shizznat
Level 1 Expert
jdthefixer
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
