Question about KitchenAid KSB560 5 Speed Blender
I bought a new interlocking collar for my Kitchenaid blender, and now it doesn't seem to be fitting on the base properly. It's resting on the base rather than going all the way down, if that makes sense. The collar totally fits the glass part and is the same as my old busted one (which also isn't fitting now, coincidentally!) Am I crazy, and missing something totally obvious?
Ross Keen
  • KitchenAid Master
  • 1,364 Answers
Remove the collar from the jug and have a good look inside, there is a circular ring inside the collar that needs to engage correctly with a glass finger on the jug. The glass finger goes between 2 plastic fingers. I think there are two of them. It was a silly idea that's been given the flick on later models.
Posted on Mar 13, 2015
Kitchenaid KSB655C5 blender locking collar doesn't go down on one side when assembled. Both sides of locking collar are away and symmetrical when off the jar.
I would say pull it apart again and fiddle about with it a bit paying some attention to that spring loaded ring that's causing you grief. I don't have one here to look at but I know I've seen that problem before and it's something to do with that ring underneath needing to be turned to a certain position so that it engages properly. There are some notches in it that need to be in a p[articular position. We never saw that version for too long, the following model had a plastic beaker without all that rubbish on the bottom.
Feb 11, 2017 | KitchenAid Blenders
How do I remove old blade?
Hi Paul,
There is a collar on the base of the jar that screws onto the jar. You will need to unscrew the collar and fit a replacement blade. make sure the seal is replaced with the blade and the collar is screwed back securely.
See this link for the parts of the blender.
CUISINART CANADA SmartPower Premier 600 Watt Blender CBT 500C
Also see the product description for the blade.
https://www.youtube.com/watch?v=rdBxUAsT_TQ
Mar 04, 2015 | Cuisinart Replacement Cbt-Bg-1 Blender...
How to remove the cutters on model ksb560mco [email protected]
The cutters are part of the collar itself and not available as a separate part. If there is anything wrong with them you need to replace the whole collar. The collars are available on Amazon UK, K A Parts as well as other places.
Dec 31, 2010 | KitchenAid KSB560 5 Speed Blender
The plastic base the blades are fitted in ,cracked need to order replacement
the part is Black and Decker Blender Base Collar Ring BL5000-11
However these are prone to cracking. I ordered a second after my first cracked, and the second one cracked after just a couple uses.
Jun 09, 2010 | Black & Decker BL1900R Blender
How to replace glass jug
Watch this video. If your jar has a lid that screws in rather than pushes in you unfortunately have to purchase a new lid, blade, gasket and collar.
May 08, 2010 | KitchenAid KSB3 Classic Work Top Blender
My son shove the mixing jar into the base when it
Hi, it is quite easy to replace. The simplest way is to use the spanner provided here:
http://kitchenaidblenders.co.uk/Home/tabid/36/p/Two-%282%29-KitchenAid-Blender-Coupler-%2b-WS-Fitting-Tool-9704230_2plusWS/ProductID/175/Default.aspx
instructions at:
http://kitchenaidblenders.co.uk/Howtoremoveablendercoupler/tabid/219/Default.aspx
Dec 28, 2009 | KitchenAid KPCB348PPM Pro Line Series...
Blender base cog is stripped. Can it be replaced
yes you can get a new base. your best bet is to google the brand name and buy the part from the manufacturer
Aug 12, 2009 | Blenders
Blender blade not turning, rotating piece on base not connected
this is getting more and more common there is a part between the motor and the drive gear that snaps for no reason . its job is to snap if the blades jam as a "fuse" to save your house from a overheating ,jammed motor . the problem is there are no parts to buy to fix this . if its new take it back to where you bought it . otherwise shipping it 2 ways for repair to the factory is sometimes as much or more as a new blender ........ i would recomend you do one of two things : go to a goodwill or other type shop and get a nice vintage blender , it will last forever ! or move up to a vita mix . its costly but it will realy last you ... this new made in china junk is just bad news even when it has the kitchen aid name on it . its still the same junk ..... good luck........ Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 24, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
KitchenAid KSB560 5 Speed Blender Logo
178 people viewed this question
Top KitchenAid Blenders Experts
Appliance engineer
ThaMp3Doctor
ThaMp3Doctor
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
