storm is an ISUZU
and had 3engines,which one? below is off wiki on storm.
1.6 L
SOHC 4XE1 I4
1.6 L
DOHC 4XE1 I4 1.8 L
DOHC 4XF1 I4coil makes 50,000 volts (even 1kv makes fire, but is too weak spark
spark plugs dead , right? all 4 right?
ever do a 60k mile tune up ? if not why not, it gets new spark parts then..
also, if the cam timing is off. the dizzy sparks between towers
make the distributor useless, it cant distribute spark.
so the first tests are .
static ignition timing. (yes, a tool, called a timing light for $20)
if timing is good the the wires HV are bad.
if timing is bad, bingo..... this is the first test on any motor.
if the timing belt or chain on any SOHC or DOHC engine slips
the dizzy will be way to h3ll off.
learn to use a timing light, and works 100% cranking.
look at that distributor cap (replace it)
see the coil wire , center, that is at 50kv spark.
and see that rotor, if the spark is good at the cap pins 1 to 4
then the dizzy is timed.
if the spark dont reach the spark plugs that means
the wire are bad or the spark plugs are shorted, or both.
its that simple. using a real spark testing tools tells you the KV.
kv = kilovolts. the best tools $5 bucks have and adjustable gap
this car is not 100kv, like newer cars and must be set (tool) to 50kv or tad less to show full powerful spark.
take care not to get shocked, keep hands off the parts
as friend cranks (or remote start button tool)
