Question about Jenn-Air JES8850 Electric Kitchen Range
Knob Noise The first left burner knob makes a frequent ticking noise
Posted by Neaemil on
Anonymous
You have a high frequency power supply close by. Most likely a track lighting system that is causing the clicking
Posted on Jan 15, 2008
I was just cleaning my cooktop and now I'm getting a constant ticking noise. I turned all burners on, left them on a short time, turned them off and it's still making the fast ticking noise. Is...
what that clicking is , is the ignitor trying to light the burner, its electronic, and if it continues it will eventually burn out, more than likely what happened is that moisture from cleaning got into the knob and control for that specific burner, and needs to dry out before it burns out, , you can try turning that one burner on and off a few times o see if that shuts it down, if it doesn't,, unplug the unit, and wait until it dries out on its own
Sep 14, 2011 | Whirlpool Kitchen Ranges
We have a ge cooktop (gas). even though the knobs are turned off , we can hear "tick tick" noise from one of the burners.
Unplug your cooktop for 24hrs and retest. Sometimes moisture gets into the switches under the knobs and can cause a short. If this continues after you let the unit dry out then your will need the replace the switches/or switch harness.
Hope that was helpful please rate me a "4" if that helped.
Dec 13, 2010 | GE Cooktops
Blowing cold air and the pilot lite is lite but no burners come on and the on/ off knob for the gas the part that is underneath the knob is making a ticking noise? If that box is the problem can we change...
You have to verify if you are getting 24v to the gas valve. If you are and the burners wont lite then replace the gas valve. They sell em at Sunberg (located thru out the use). If you dont have 24v then check the transformer. If you do have 24v at the transformer, take two wire from the transfomer 24v and put them directly to the gas valve to see if it will light. let me know what happened.
Mar 20, 2010 | Heating & Cooling
We have a belling gas hob. Intially when we turn on the control knob it gave a ticking sound even after it got ignited. then when we were turning on one burner it gave ticking sound in all burners . but...
take out the control knobs. clean the grease and food partilcles if any using hot water and dish washing liquid .if the washer under the knob is stuck, put it properly and put the control knobs back into it carefully
Jan 11, 2010 | Stainless Cooktops
Gas burners are ticking
The ticking sound you hear is the electronic ignition which is located by each burner. When you turn a burner on the electronic ignition creates a spark which ignites the gas. Once the burner is ignited. turn the knob a bit further and the ticking will stop.
Feb 05, 2009 | DCS RGS-486GD Gas Kitchen Range
Super Capacity 465 Gas Range
my gas stove top burner will not ingnite when I turn on the gas.
I have gas supply to the house, the gas stove top makes the tick tick noise when you
turn one of the burners on, but no flame, even if you try using a match.
What all can I checK?
Sep 20, 2008 | Kitchen Ranges
Range burners
There must be a problem in one of the switches which is behind one of the knobs. Will have to check each switch with a meter.
Oct 03, 2007 | Tappan TGFS_63 Gas Kitchen Range
Ticking Sound of spark igniter persists
Our GE cook-top burner igniter has started ticking even when the oven is shut off. Even after cleaning the bottom of controls the ticking persists. Any suggestions? Thanks
Aug 27, 2007 | GE 36 in. JGP628 Gas Cooktop
Jenn-Air JES8850 Electric Kitchen Range Logo
139 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Paul Carew
Ismael Rodriguez...
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
