Harbinger APS12 12 Powered PA Speaker Logo
A
Anonymous Posted on Mar 02, 2015
I need a schematic for the Harbinger V2115 600 watt powered speaker
Frederick Electrick
Level 3:
Master:
  • Master 350 Answers
  • Posted on Mar 04, 2015
Frederick Electrick
Master
Level 3:
Master:
Answers
350
Questions
Helped
107197
Points
1344
This schematic is not available?
you will need to contact the company...
http://harbingerproaudio.com/product/v2115/
1helpful
Harbinger ha120 no sound to speakers. What's wrong?
It could be a number of things. Does the head light up when turned on? Are the controls on the channel turned up? Is the master turned up? Have you checked continuity on the cables? Have you tried the speakers with another amp, or the amp with other speakers? This will help narrow down the problem.
2answers
Why does my harbinger aps15 speaker keep blowing fuses when powered up.
probably shorted the integrated amp chip...they are not worth the trouble to fix..buy some good equipment.
Crossover schematics
measure it with a fluke or similar multi-meter
Speaker shorted out
If you do not have training in electronics you can cause serious damage to yourself trying to fix this. You will need to take this into the shop.
2answers
Low volume for a 180 watt amp, does this amp have one 180 watt power amp or two 90 watt power amps?
If there are stereo effects , like chours and delay it more than likely has 2 90watt amps
The compression speaker does not work
Here is your schematic for the power amp. There is a separate amp for the tweeter using a LM3886 which is fairly well protected. Open the unit and test the tweeter driver.
http://elektrotanya.com/behringer_b215a_power-amps_psu_sch.pdf/download.html
Scroll down to "Get Manual" and click on it to download the schematic. At the site is also the preamp section as a separate schematic. You probably don't need that for the failure you are seeing. A lot of the tweeter drivers seem to get blown up, but once you test you will be able to find if the problem is in the amp or the driver.
1helpful
2answers
Hello My Harbinger APS15 has a constant clip light lit. We can't get any output from the unit and it's just a couple of months old.
Likely the power amp has shorted to one rail... DO NOT attempt to use it as it could be sending high current through the speaker causing damage. Age of the unit doesn't have much to do with it. Take it in for repair. Unless you are electronically adept and can get a schematic this is not DIY.
Top Harbinger Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Harbinger Music Expert? Answer questions, earn points and help others
