Question about Home
We just had a Koehler bathtub installed. Now the tile on the back right wall is cracking and the floor freaks due to flexibility of tub. Who should we contact?Koehler or contractor?
Posted by laura on
We are concernened about screwing the tub into the floor for stability. We have to go through tile and into wood. There are no instructions included for this. Included were 5/16 lag bolt and feet but we do...
The main reason to screw the feet to the floor is to keep the tub from moving which could cause the pipes to leak (either the supply or the drain) Authentic old clawfoot cast iron tubs were usually bolted to the floor because they were so heavy that it took a significant effort to move them, especially on a wood floor. If your tub is light enough that you could move it without a pretty significant push, then you had best bolt it to the floor in at least two places. Drilling holes through tile can be intimidating, but it's not as hard as you might think using an inexpensive masonry drill bit and a carbide tipped scratch awl. I will leave it to you to figure out how to assemble the claw feet to the tub, but here are a couple of important tips for drilling the holes through tile: Mark the hole locations with a felt-tip marker. Then use the carbide tipped scratch awl to gouge a starter divot in the tile. This divot can be pretty small, but it's essential for being able to drill a hole in tile in the right place. Use a variable-speed drill at fairly low speed to drill the hole - don't use a hammer-drill. Also keep a puddle of water where you are drilling to prevent the tile from heating up in one spot and causing the tile to crack. Once you get the hole through to the wood below, switch to a regular drill bit of a smaller size. Good luck, Al K
Aug 24, 2010 | American Standard Reminiscence...
How to put bath supports onto new fibre glass bath.It does not have a wooden frame, do I need to make one?
You mean a tub surround? You have no box for the tub to sit in? What were planning on using to hide the sides of the tub? Most big tubs, whirlpools, jacuzzis, etc, sit in a frame work of two by fours and plywood, the ply top supports the tub and the tile, The ply walls or tile board walls are needed for the tile, access to the motor is necessary if you don't have a panel on the tub itself. The tub is set in a finished box, all the tile work done on the top, and set in a ***** of concrete for support. This is for tubs with no sides on them, some tubs have one side finished, and they go up against the walls, and get tiled over the lip. But they get set in mud too. But no walls, just a band against the wall for support. I have seen every tub in every house we have worked on for 25 years done this way, it works. Check it out. Hope this helps. And I hope this is what you are talking about.
Jun 01, 2010 | Home
Bathtub installation
Now I see the wood stud is added support and the tub should rest on it. though it is not to hold the tub up. Like a man using a cane the cane doesn't keep a man standing by itself. Rather it helps a person be more stable that's what the stud does. Set at height for a level tub.
Here is a trick as well for supporting the back of the tub (Shimming) Get some of the expandable foam. Set everything in place like the wood ledge when you have everything in place and tub pre-fitted. Remove tub and place a line of foam along back side. Place tub in place and when foam expands and dries it will become your perfect shim. Hope this helps, thanks for using FIXYA. Good luck, Jeff
Apr 08, 2010 | Maax Home
My jacuzzi bathtub plastics pipes underneath are leaking due to being chewed by rats. So if i fill up the tub to the jacuzzi line holes, water leakes through the chewed pipes on to the wood floor...
no there is no solutions for plugging off the jets so the water doesn't go in them. you will have to pull the tub and repair the lines. no access panel just means you have to dig in!
Feb 23, 2010 | Whirlpool 5"x36" White Bathroom Drop-in ...
One tile in the first row up from the tub fell out and the wall behind where the tile came out is soft and not ridged at all to glue the tile back in place the wall is plaster nd lath im letting it dry...
Wetted plaster often dries out like dry sponge cake. When dry try a spray of 25% pva solution. This soaks in and solidifies and stabilizes the plaster.
Whatever you do keep it dry from further water
Dec 01, 2009 | Home
I have an aqualux whirlpool tub w/ cracked jet housing
yes i can do it call me 301 659 9968 rick
Oct 15, 2009 | Home
Installation of our whirlpool tub
Your sheet rock will go to the top of the lip of the tub and then your tile will overlap this lip. If it isn't done right, your grout will crack if you are tiling.
Mar 22, 2009 | Home
Tile over a cracked cement floor
You can get a crack membrane to put over the cracks. First use a primer on the floor, this is a primer just for this application, then put membrane on top of primer. these products can be found at home depot or lowes or any tile store.Also do not use cheep thinset. the better thinset is more flexible and will absorb any movement. The cement board would not work as they will move or flex and cause the grout to crack and tile to loosen
tom
Nov 13, 2008 | Mk Diamond 154861 MK-100 7'' x .060'' x...
How to install claw foot bath to tiled floor
Hi giacomjo,
I'm Harvey the Master Plumber.
Your question is: You have a claw foot bath to install in a tiled bathroom. How do you fix the bath to the floor so it is secure and doesn't move?
A little clear silicone caulk under each claw is my favorite method. Locate the tub in it"s final position. Set up the drain and water connections so that you can complete them without moving the tub. Lift each end in turn just a bit and aply some caulk, you may need a helper. Wipe off the excess. Then hook up.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 13, 2008 | Home
Home Logo
99 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
