Washing Machines Logo
Question about Electrolux Washing Machines
Eho fault electrolux 1067 washing machine
Posted by chana over on
tom cassidy
    Genius:
  • Electrolux Master
  • 1,585 Answers
Check pump for blockage
Posted on Mar 02, 2015
What does error EHO in electrolux EDC2086GLW drayer with condensor refers to
The EH0 error indicates a problem with the incoming voltage or the power supply or wiring inside the dryer. If there has been a problem with the electricity coming into your home (brown out or similar), the error will resolve when the power company fixes the issue. Otherwise the control board is not receiving the expected power from the power supply.
First unplug the dryer or shut off the power at the circuit breaker. Unplugging the dryer for at least 30 seconds will reset the error message. If you can, plug another appliance into the outlet and check if that works. If there is a wiring fault, get an electrician to check the outlet and wiring.
If the problem is inside the dryer, the power supply, the control board and the wiring to the control board will need to be checked. There could be a loose wire, a broken wire or a spot where the insulation has been damaged and two wires are touching. Check all of the wiring harnesses where groups of wires plug into the control board. Replace or fix any damaged parts or wires. The parts diagrams are available here: https://www.ransomspares.co.uk/parts/brands/electrolux/tumble-dryers/edc2086glw%20(91609724100)/ . If the dryer is under warranty, contact Electrolux to have the unit serviced.
I hope this helps.
My electrolux type EWF10842, on display find error EHO, what mean this error,and how to resset, thanks
The EHO (or EH0) error indicates a problem with the incoming power or an electrical problem inside the washer. Unplug the washer for a while to reset the error code. Next check your wiring and make sure that the outlet doesn't have a fault. If you live in an area with brown-outs or wires that touched during a storm, wait until the electricity is repaired. Then check if the power supply to the washer was damaged by the surge or changing power levels.
If these aren't responsible for the problem, you'll need to check the wiring for shielding damage, the wire harnesses and the rest of the washer. There is a parts diagram here: http://docplayer.net/60693214-Spare-parts-list-household-washing-machines-pnc-elc-brand-model-market-electrolux-ewf10842-th-washing-machines-front-loaded.html .
I hope this helps.
EHO message on Electrolux EDP2074PDW dryer
On Electrolux dryers, the EH0 (EHO) error indicates a problem with the incoming voltage at the power supply. This can be due to a problem with the electrical outlet, the power supply or the circuit board.
First unplug the dryer or shut off the circuit breaker. Check if the outlet is working by plugging something else into the outlet and checking if it works. Leave the appliance off for 30 minutes or an hour to see if the error resets. If you recently had a power outage, this might clear an issue from an electrical surge. You may want an electrician to check your wiring.
After that, you will have to check if the power supply is working properly or if the circuit board is getting the incorrect voltage information. There should be an wiring diagram and test sheet tucked into the dryer. It's usually in a space accessed from the back of the dryer. Replace the faulty part. If the dryer is under warranty, contact Electrolux and have them service the problem.
I hope this. The parts diagram is available as a PDF here: https://spares.bigwarehouse.com.au/index.php?cPath=64689_77656_94810 .
1helpful
My Electrolux front loader machine is showing EHO in the display, it won't move off it no matter which program I try to display, can you please help me?
The power supply is failing and needs to be replaced but first try the steps provided in the link below. Washing machine displays error message EHO EH0
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
2helpful
2answers
My washing sent in control panel alarm is ( EHO) what problem model ( zanusssi zwf 16581w)
C\nt find a fault code EH0. EH1 EH2 AND EH3 all relate to power supply problems voltage to high or low . the electronics dont like a dirty supply spikes and fluctuations upset them. they dont always work from a small generator supply.
4helpful
Hi, We have an electrolux EWF1074 which is reporting error EHO There is no mention of this in the manual or on Google after a brief browse. Please advise. BK
First of all is the machine doing anything it should not be.That alarm code does not exist on our system,the closest is EH1 and this relates to Power supply problems or a faulty PCB.To cancel press and hold the start/pause button and the nearest option button for about 5 seconds,now turn the programme knob to position 10 then hold in the start/pause button and option buttons again till alarm disappears and E00 is showing.Then turn dial to 0 then back to position 1 then back to 0 to cancel operation.
Hope this helps.
2answers
My Electrolux Washing machine has fault code
www.electrolux.com.auGo here and type in the model in the search bar and download the manual for the machine this will help
Open Questions:
Top Electrolux Washing Machines Experts
nu267
tina gallow
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
