Metra Ford F 150 Truck 1999 Logo
A
Anonymous Posted on Mar 02, 2015
IGNITION KEY CODE 1FDRE14L7XHB49130 IGNITION KEY CODE
Ray Lozano
Level 1:
New Friend:
  • Contributor 30 Answers
  • Posted on Mar 06, 2015
Ray Lozano
Contributor
Level 1:
New Friend:
Answers
30
Questions
0
Helped
7858
Points
62
Anonymous,
If the key code isn't written on the passenger key lock tumbler (this is where it is on most cars) then you'll have to go to the dealership to get the code. Get ready to give up some personal information, and sign some forms because they don't want you to go all "Gone in 60 Seconds" on them. I hope this helps, Ray
What is anti theft code 17 2000 ford explorer
How are you coming up with a code 17 ?
PATS Diagnostic Trouble Code (DTC) Index
PATS Diagnostic Trouble Code (DTC) Index DTC Description Action B1213 Anti-Theft Number of Programmed Encoded Ignition Keys Below Minimum GO to Pinpoint Test B1213 . B2103 or B1232 Antenna Not Connected Defective Transceiver GO to Pinpoint Test B2103 . B1600 No Key Code Received - Damaged Encoded Ignition Key or Use of Non-PATS Encoded Ignition Key GO to Pinpoint Test B1600 . B1601 Unprogrammed Encoded Ignition Key (Keycode Format OK) GO to Pinpoint Test B1601 . B1602 Invalid Key Code Format From Encoded Ignition Key Transponder (Partial Key Read) GO to Pinpoint Test B1602 . B1681 PATS Transceiver Signal Is Not Received (Not Connected, Damaged, or Wiring) GO to Pinpoint Test B1681 . B2139 PCM ID Does Not Match Between PATS and PCM GO to Pinpoint Test B2139 . B2141 No Security ID Exchange Between PATS and PCM GO to Pinpoint Test B2141 . U1147 Faulty SCP Link or Incorrect PCM Calibration GO to Pinpoint Test U1147 . U1262 Missing SCP Message REFER to Section 418-00 .
Replaced ignition switch vehicle will not start appears to be computer code
Is there a computer related code which I must enter via the radio ??? You don't enter anything through the radio !!!!! Having factory service repair info so you can read how the anti-theft system works an a scan tool to pull DTC'S - diagnostic trouble codes is the proper way to diagnose .
The theft deterrent system has been incorporated into the body control module (BCM). The theft deterrent is provided in order to prevent the vehicle operation if the correct key is not used in order to start the vehicle. The ignition key turns the lock cylinder. The cylinder rotation produces an analog voltage code in the Passlockā„¢ sensor. This voltage code is received by the BCM. The BCM compares the voltage code to the previously learned voltage code. If the codes match, a class 2 message is sent from the BCM to the powertrain control module (PCM)/vehicle control module (VCM). The message enables the fuel injectors.
The design of the Passlockā„¢ system is to prevent vehicle theft by disabling the engine unless the ignition lock cylinder rotates properly by engaging the correct ignition key. The system is similar in concept to the PASS-KeyĀ® system. However, the Passlockā„¢ system eliminates the need for a key mounted resistor pellet. The components of the Passlockā„¢ system are as follows:
ā€¢ The ignition lock cylinder
ā€¢ The ignition switch
ā€¢ The Passlockā„¢ sensor
ā€¢ The Body control module (BCM)
ā€¢ The security telltale
ā€¢ The vehicle/powertrain control module (VCM/PCM)
Your best bet , take it to a qualified repair shop.
2004 Sabb, the ignition will not turn to start the car. No issues before with ignition.
MAKE SURE YOU DONT HAVE THE WRONG KEY.TRY ANOTHER KEY.PUT KEY IN THE IGNITION SWITCH.TURN IGNITION TO THE ON POSITION.WHEN LED FLASHES TWICE THAT INDICATE KEY IS RECOGNIZED.IF KEY CODE NOT RECOGNIZED A MESSAGE ON THE TRIP COMPUTER WILL BE DISPLAYED.TO ENABLE ENGINE TO START WHEN KEY CODE NOT RECOGNIZED.SWITCH THE IGNITION ON.PRESS ANY KEY REMOTE TRANSMITTER BUTTON ONCE START THE ENGINE.IF ALL FAILS. THE KEY SWITCH TRANSPONDER FAILED OR THE KEY LOCK CYLINDER BROKEN, IMMOBILIZER MODULE FAULTY VECHICLE HAS TO BE SCANNED TO LOOK FOR FAULTY IMMOBILIZER MODULE.
I have a 2001 chevy Blazer with automatic transmission. My ignition will not turn from the lock position. We have tried to turn the steering wheel and turn the key at the same time but it wont budge. We...
you can get a new ignition switch -- but my thought on the matter ( I'm a locksmith ) -- is you might try and see if you can go to a lock shop and see if they can read your key and make a new key to factory spec's. one other thing that causes problems is to many keys on your key ring ( weights down the key when in the ignition and driving -- causing excesive wear on the key AND on the ignition ).. -- if you bought the truck new look to see if you have the ' key code ' writen down somewhere,, or you might be able to get the code from the dealer (?) -- but do not get your keys made from dealer or let them work on the ignition ( way to expensive !!! ) --- go to a auto locksmith and let them look at what you got ( let them look at your key first ). -- ( key by code and/or a key read, only costs about $15 - $20 buck ).
c...
8helpful
My 1998 ford expedition won t start and the theft
the light blinks when the system is armed. Normal.
Your key has to be able to communicate with the receiver in the ignition area. Does your other key work ok?
Anti-Theft The passive anti-theft system (PATS) uses radio frequency identification technology to deter a driveaway theft. Passive means that it does not require any activity from the user.
  • During each vehicle start sequence, the ignition key identification code is requested by the PATS module.
  • If the key's ID code has been programmed into the system, the vehicle powertrain control module (PCM) (12A650) is allowed to operate; this allows the vehicle to start.
  • If the key's ID code is not programmed into the PATS module, or if no encoded key is detected, then the vehicle PCM is disabled.
The PATS module, located under the driver side instrument panel, communicates the state of the security system to the PCM via the module communications network. The PCM, based on the communications from the PATS module, will determine if the vehicle's engine will be enabled to start. If the PCM prevents the vehicle from starting because of PATS, the PCM will store a DTC in memory.
The anti-theft vehicle protection system utilizes the THEFT indicator, located in the instrument cluster (10849), when the ignition switch is turned to the RUN/START position. The indicator provides system prove out and operating status to the customer or technician.
Each PATS ignition key holds electronics that give each key a unique ID code.
The PATS will activate the indicator signal when the ignition switch is turned to the RUN/START position. The THEFT indicator will turn ON for two seconds, then turn OFF.
If the THEFT indicator flashes for one minute or more, this indicates that there was no key code received.
When the vehicle ignition switch is placed in either RUN or START, the PATS module requests the ignition key ID code. The PATS module requests the ignition key ID code by supplying power, ground, and the carrier signal to the transceiver to energize the ignition key. After the energize period, the key transmits its ID code to the transceiver module, which sends it to the PATS module.
The PATS module then compares the received KEY ID code to those stored in memory (16 maximum). If the ID matches, the PATS module sends an enable signal to the PCM over the module communication network.
The passive vehicle protection system utilizes the engine management capabilities of the PCM to enable or disable the vehicle engine. The module communication network is used to send and receive messages to and from the PCM.
Within one second after engine start, the PCM must receive an enable signal from the PATS module through the module communication network or the engine is disabled before the vehicle can be moved.
If the PATS module recognizes a stored ignition key code but there is a module communication network concern preventing the PCM from recognizing the start enable signal from the PATS module, the vehicle engine will be disabled. If this happens, the PATS module will flash the THEFT indicator for one minute, then flash diagnostic trouble code 16 ten times to indicate there is a problem with the module communication network circuits or the PCM is not responding properly.
The passive vehicle protection system will disable the vehicle from starting if there is a:
  • Damaged encoded key.
  • Unprogrammed key.
  • Non-encoded key (key has no electronics).
  • Wiring concern.
  • Transceiver concern.
  • Control module concern.
  • Module communications network concern.
Key Programming —Spare Key NOTE: Before starting this procedure, make sure the key(s) you want to program have the correct mechanical cut.
NOTE: Performing this procedure does not erase existing programmed keys.
  1. Insert the programmed key in the ignition. Turn to RUN.
  1. THEFT indicator proves out after two seconds.
  1. Remove the programmed key.
  1. Within 15 seconds, insert the new key in the ignition and turn to RUN.
  1. The extra key is now programmed.
Key Programming —New Key (Without Diagnostic Tool) NOTE: Before starting this procedure, make sure the key(s) you want to program have the correct mechanical cut.
  1. Insert the nonprogrammed key in the ignition and turn to RUN.
  1. THEFT indicator flashes rapidly.
  1. After 15 minutes of flashing, the THEFT indicator will stop flashing.
  1. Within five minutes after the THEFT indicator has stopped flashing, turn the ignition key to OFF and back to RUN.
  1. All originally programmed keys are now erased, and only the key in the ignition is programmed.
  1. Additional keys may be programmed; refer to Key Programming—Spare Key .
2000 contour
for 98 contour issue. TSB 98-21-14 not covered by warranty
This TSB article is being republished in its entirety to include the 1999 Cougar . ISSUE: The ignition key may be difficult to insert or remove and/or key chimes may sound with the ignition key removed and driver's door open on some vehicles. This may be caused by internal design characteristics in the ignition lock cylinder increasing insertion/removal efforts which may allow the lock cylinder to stick.
ACTION: Install a revised ignition lock cylinder. The revised ignition lock cylinder should reduce the possibility of high insertion/removal efforts and ensure proper chime function. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
  1. Verify customer concern.
  2. Observe the ignition lock cylinder as the key is removed. If the lock cylinder snaps outward to the non-depressed position and the chimes stop sounding, continue to Step 3. If it does not snap outward, replace the ignition lock cylinder with the appropriate cylinder by referring to the Parts Block in this article.
  3. Insert and remove the ignition key from the lock cylinder. If binding or high efforts are encountered, replace the ignition lock cylinder.
  4. From the Parts Block, select a lock cylinder with a part number suffix identical to the center character of the key code of the vehicle. The suffix must match the center key code character to maintain a single key system.
  5. Install the replacement lock cylinder, by referring to the 1998 Contour/Mystique Workshop Manual, Section 211-05 or the 1999 Cougar Workshop Manual, Section 211-04. NOTE: KEYS INCLUDED WITH NEW IGNITION LOCK CYLINDERS ARE CUT FOR THE IGNITION ONLY. IN ORDER FOR THE KEYS TO FUNCTION IN THE DOOR LOCKS, THE KEYS MUST BE CUT TO THE DOOR CODE OF THE ORIGINAL LOCKSET. THE KEY CODE WILL CHANGE UPON INSTALLATION OF THE REPLACEMENT LOCK CYLINDER (FIGURE 1).
    Figure 1 - Article 98-21-14
    NOTE: ADVISE THE CUSTOMER TO DISCARD ALL KEYS THAT WERE CUT TO THE ORIGINAL IGNITION LOCK CYLINDER.
  6. Record the new key code on the repair order and provide to the customer. Advise the customer to record the new key code in a permanent location and to discard all references to the original key code. NOTE: REPLACEMENT IGNITION LOCK CYLINDERS ARE SHIPPED WITH NON-PASSIVE ANTI-THEFT SYSTEM (PATS) KEYS. IF THE VEHICLE IS EQUIPPED WITH PATS, OBTAIN TWO (2) ROTUNDA KEY BLANKS (OR OTHER FORD AUTHORIZED BLANKS, SUCH AS: ILCO, STRATTEC, CURTIS, HUF, OR VALEO) AND CUT TO THE REVISED KEY CODE. USE OF OTHER UNAUTHORIZED KEYS MAY CAUSE ERRATIC OPERATION OF THE PATS SYSTEM.
  7. Program PATS keys using one of the two following methods:
(1) For vehicles with Integrated PATS (IPATS), function built into the Powertrain Control Module (PCM) and built beginning:
  • 2/2/98 Kansas City (Contour/Mystique)
  • 2/16/98 Mexico (Contour/Mystique)
  • All 1999 Cougars
Using the New Generation Star (NGS) Tester equipped with Service card (green) level 3.0 or higher:
  1. From NGS menu, select:
    • Service Bay Functions
    • PCM
    • Enter Security Access (10 minute delay)
    • Ignition Key-Code-Erase
  2. Disconnect Data Link Connector (DLC).
  3. Cycle the first non-programmed key in the ignition to run position for at least 3 seconds and then turn to the off position.
  4. Cycle the second non-programmed key in the ignition to run position. The theft indicator should prove out for 3 seconds.
  5. Verify the vehicle will now start using both keys.
(2) For Contours/Mystiques with Stand Alone PATS and built before:
  • 2/16/98 Mexico
Using the New Generation Star (NGS) Tester equipped with Service card (green) level 1.0 or higher:
    • PATS
    • Ignition Key-Code-Erase (this process may take up to 8 minutes to complete )
  2. Disconnect DLC.
  3. Cycle first unprogrammed key in the ignition to run position. First key will program and allow vehicle to start.
  4. Again cycle first programmed key to run position. Within 15 seconds, remove original key and turn new unprogrammed key to run position. The theft indicator should prove out for 2 seconds. New key will start vehicle.
  5. Repeat this process for additional key programming. NOTE: THE FOLLOWING SHOULD BE NOTED FOR THE PART NUMBER BLOCK:
    • Part Number suffix will match center character in key code
    • Logo on key is Ford for Contour models
    • Logo on key is Mercury for Mystique and Cougar models
PART NUMBER PART NAME F5RZ-11582-A Ignition Lock Cylinder (Contour) F5RZ-11582-B Ignition Lock Cylinder (Contour) F5RZ-11582-C Ignition Lock Cylinder (Contour) F5RZ-11582-D Ignition Lock Cylinder (Contour) F5RZ-11582-E Ignition Lock Cylinder (Contour) F5RY-11582-A Ignition Lock Cylinder (Mystique, Cougar) F5RY-11582-B Ignition Lock Cylinder (Mystique, Cougar) F5RY-11582-C Ignition Lock Cylinder (Mystique, Cougar) F5RY-11582-D Ignition Lock Cylinder (Mystique, Cougar) F5RY-11582-E Ignition Lock Cylinder (Mystique, Cougar)
15helpful
3answers
How to reset my factory car alarm in a 1999 mercury cougar v4 2.0? thanks
1999 cougar. before they tell me I need a fuel pump I want to be SURE the anti theft system has not shut off the fuel to the engine.
how do I confirm that?
31helpful
4answers
Code to program my key fob
Here are the program instructions
1. Close the vehicle doors.
2. Turn OFF the ignition.
3. Remove the key from the ignition.
4. Press and hold the driver side door lock switch in the UNLOCK position.
5. Insert the ignition key into the ignition lock cylinder and remove the key. (Do not turn the ignition key in the lock cylinder.)
6. Insert the ignition key into the ignition lock cylinder and remove the key. (Do not turn the ignition key in the lock cylinder.)
7. Insert the ignition key into the ignition lock cylinder. (Do not turn the ignition key in the lock cylinder.) Leave the ignition key in the ignition lock cylinder.
8. Release the door lock switch. The vehicle will sound three beeps in order to verify the Program Mode has been activated.
9. Press the LOCK and UNLOCK buttons together on the keyless entry transmitter and hold until the vehicle beeps twice to verify that the transmitter has been successfully programmed (this take approximately 15 seconds).
10. Perform the previous step to program up to four transmitters (including your old ones).
11. Remove the ignition key in order to exit the Program Mode
1997 ford contour
this is for 98, but may apply if yours is late 97 build.
Article No.
98-21-14
  • IGNITION SWITCH - HIGH EFFORT IGNITION KEY INSERTION/REMOVAL AND/OR KEY CHIMES SOUND WITH DOOR OPEN AND IGNITION KEY REMOVED
Publication Date: OCTOBER 15, 1998
FORD: 1998 CONTOUR LINCOLN-MERCURY: 1998 MYSTIQUE
1999 COUGAR
SERVICE PROCEDURE
  • All 1999 Cougars
    • PCM
  • 2/16/98 Mexico
    • PATS
  2. Disconnect DLC.
Top Metra Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
