Crosley Washing Machine CAH4205AWJ, CAH4205AWW Replacement Washer Door Boot Drain Logo
A
Anonymous Posted on Mar 02, 2015
Crosley CAH4205AWW washer machin wont spin....???????
My washer won't spin or agitate?
tom cassidy
Level 3:
Genius:
  • Crosley Master 1,585 Answers
  • Posted on Mar 02, 2015
tom cassidy
Crosley Master
Level 3:
Genius:
Answers
1585
Questions
Helped
323078
Points
3520
Kenmore elite model 23012101 wont agitate, but fills and spins What could the problem be?
It could be the agitator dogs (which can cheaply be replaced). It is not the motor coupling as it spins. If the aggitator assembly is broken, that is another matter. Here is a video related to replacing the dogs. https://www.appliancepartspros.com/repair-help/kenmore-washer-11023012101-repair/11023012101-will-not-agitate.html Here is text about the dogs. https://homeguides.sfgate.com/obsessively-clean-gadgets-13771620.html and
https://www.cheapapplianceparts.com/kenmore-whirlpool-washer-repair/kenmore-washer-wont-agitate/ Here are other possible causes for the problem. https://www.dependableservices.com/blog/washer-wont-agitate-but-spins/
Sears offers diagrams, parts, and instructions. https://www.searspartsdirect.com/model/4577n2kq1q-000583/kenmore-elite-11023012101-washer-parts
The following site offers an agitator repair kit. I have no idea what is in it but you could inquire. The point is, you have to step by step eliminate the possible causes. And to DIY it, you have to locate the instructions about testing each possible cause in turn. Sears offers diagrams and so forth. There may be additional YouTube videos about each possible cause and a procedure.
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/40-6--/Kenmore-Washer-Won-T-Agitate
Why is it not spinning out
Ok is it at least washing? if so may not be ur motor coupler? if direct drive. But may be a bad clutch or tranny? Even a bad belt if belt driven? sometimes even a bad door switch will not allow it to go into spin? u can check with a multi meter.
Does not fill
nF = no fill so you need to check the water valve see it the screen is clogged or if the water valve is recieving electricity during fill mode. I bet on a clogged screen
1helpful
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Won't spin
If a washer will agitate and wont spin check the lid switch. Lid switches are designed to not allow spin on most washer but will allow agitate. Safety feature.
If you need further assistance please feel free to comment me back.
33helpful
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
1helpful
Wont spin does everything else but spin
Your spin cycle control seems to be bad. This is also called your timer. Check for power supply by pulling off your top panel and checking for power everywhere.
Machine won't agitate or spin
Dear customer,
 We recommend u to do the following when the washer doesnt spin or agitate,
  1. Test the lid switch
  2. Inspect the motor coupler
  3. Inspect the drive belt (belt drive only)
  4. Inspect under the washer for soot (clutch)
  5. Test the motor
  6. Inspect the pulley
  7. Test the transmission
  8. Inspect the agitator
  9. Inspect the pump coupling
  10. Test the timer control
  11. Test the centrifugal switch
  12. Test the water level switch
for more details about self testing plz try the link  http://www.acmehowto.com/howto/appliance/washer/washer.php
Plz rate this solution.. thank you..
Top Crosley Washing Machines Experts
vince
ADMIN Andrew
ADMIN Andrew
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
