Question about Amerock Hardware & Accessories
How do I reverse a door handle on a hollow core door so the latch will close from the inside instead of the outside?
I don't know the make of handle but it has a horizontal lever
Posted by Steve on
  • warner45w
    warner45w Jun 15, 2018
    Burger King is an American global chain of hamburger fast food restaurants. It is headquartered in the unincorporated area of Miami-Dade County, Florida, United States.
    bk working hours |
    bk timings
Anonymous
Most of the time all you need to do is swap the two handles and flip the latch over so the angled part of the latch is on the other side, so it will self latch when you close the door.
Posted on Mar 19, 2015
2000 ford f 150 supercab back door on drivers side will not open
The cable runs from the latch to the handle, it sounds like the cable broke off one end or fell off,
this truck uses cables instead of metal rods to open the latch, remove the door panel and see if the cable fell off handle area or latch,,
the cable operates the inside door handle and sometimes the outside handle but very rare that it operates the out side handle to open door.
Nov 09, 2012 | Ford F150 Cars & Trucks
My rear passenger side door will not close
Just use the outside door handle and pull on the latch that is closed. If you use the inside door handle then you will have to undo the child lock.
Pull on the latched that is closed while holding the outside door handle....Make sure that it is unlocked...
Dec 29, 2011 | Ford Focus Cars & Trucks
Driver's door won't open inside or out. Power locks work but inside and outside handles dont release latch. Can I get door panel off in the closed position, otherwise any way to open door
Hey, You need to remove the panel otherwise u can't reattach the metal sticks that move the locks, but i think it's hard to remove it in a closed posision when u don't brake it
May 16, 2011 | Saturn Vue Cars & Trucks
Have a 1998 Jimmy, the driver door is stuck in the close position and can not close the door. The handle seems to be working properly; inside handle moves the cable that permits the door to close and...
with the door open see if latch is stuck in close position . If so hold handle open and pry with screwdriver to open latch ..If that works latch needs to be lubed for smooth operation
Feb 17, 2011 | 1998 GMC Jimmy
Have a 1999 ford explorer xlt got out of truck and the passenger door won't close tried locking and unlocking door to no avail. So now my passenger door won't close. What is wrong
It is possible the latch mechanism closed after opening the door. Get a flat blade screwdriver and stand outside your truck, looking at the door latch area. you should see a small flat arm that is making a closed loop in the area where the door striker goes. Stick the screwdriver inside the loop and gently pry outward on the loop as you pull the door handle. That loop is actually like a tongue that should flip inwards towards the truck as you pull the handle. There are a few different ways you could possibly flip the latch back, depending on the exact configuration of the latch assembly. Usually on my wife's van we have to put the screwdriver through the loop from the outside and rest the tip on the door. Then, as we pull the handle, we move the handle of the screwdriver toward the vehicle which flips the latch back down so the door striker post can go inside the latch. I hope this helps and please rate my solution - I'll wait a little while to see if it works for you - if not let me know right away and I'll try to help you figure this out. Thanks for using fixya!!!
Jan 04, 2011 | 1999 Ford Explorer
My rear passenger door will not close. It just
Look on the very end ot the door you will see where the recieving latch is.This is where you spay.You need to make sure that the latch didn't fall into the closed position.You can look at the latches on the other doors to see what they look like in the open position.You can take a flat screwdriver to flip the latch back and forth while you hold the handle.
Jan 16, 2010 | 1998 Volkswagen Golf
ELECTRIC DOOR LOCKS ONLY LOCK SOME TIMES
if you hit the lock button a couple times, will it finally lock?
If so, then you will need to take door cover off and lube up the connectors as they probably got corroded.
Aug 14, 2009 | 2000 Ford F350 Super Duty Super Cab
Doors won't close
Manually UNLOCK the door button or slide. HOLDING the OUTSIDE DOOR HANDLE in the OPEN position, with your other hands finger, LIFT OPEN the latch, and close your door. Hope this helps.
May 24, 2009 | 1994 GMC Sierra
Rear door on driver side won't open,have taken the panel off the inside of car,seems like the lock won,t travelas far as it does on the other door.is there any way to open this door,thanks[1997 lincoln...
Rear
Removal
  1. Using a small screwdriver, remove the screw cover from the armrest of rear door trim panel (27406).
  1. Remove the two retaining screws.
  1. Using Trim Pad Removing Tool from Rotunda Windshield and Moulding/Trim Removal Kit 107-R0401 or equivalent, pry rear door trim panel from door inner panel.
  1. Disconnect electrical connectors.
Installation
  1. Position rear door trim panel on door inner panel, aligning two locators on rear door trim panel. Reverse Removal procedure.
------------------------------------------------------------------------------------ Rear
Removal
  1. Remove door trim panel and watershield. Refer to Section 01-05 .
  1. Check all connections of remote control links and cables. Service as necessary.
  1. Remove remote control assembly.
  1. Remove door latch remote control assembly from latch assembly.
  1. Drill out rivet at bellcrank and link (264B14).
  1. Remove three screws attaching latch assembly to door.
  1. Drill out rivet that attaches actuator motor to door.
  1. Remove latch assembly with actuator motor and door latch control rod lever link assembly.
Installation
  1. Install new bushings and clip onto latch assembly.
  1. Install latch with links and power lock actuator into door cavity.
  1. Position latch assembly to door, aligning screw holes in latch and door. Install three screws. Tighten to 10-13 Nm (89-115 lb-in).
  1. Attach door latch actuator motor to door with a new rivet.
  1. Install bellcrank and link to door using a new rivet.
  1. Install inside door handle and remote control assembly to door.
  1. Open and close door to check latch assembly operation.
  1. Install watershield and door trim panel. Refer to Section 01-05 .
Item Part Number Description 1 221A00 Door Handle to Door Latch Actuating Cable 2 26446 Rear Door Control Rod Retainer 3 377901 Plug Button 4 26412 Rear Door Latch 5 W623451-S2 Push Nut 6 224A32 Counter Balance 7 22450 Door Outside Handle Tension Spring 8 W701210-S309 Screw 9 224A20 Outside Door Handle Anti Rattle Pivot (2 Req'd) 10 22404 Door Handle 11 224A24 Front Door Outside Handle Spacer (2 Req'd) 12 264A64 Rear Door Actuating Rod 13 22408 Outside Door Handle Anti-Rattle Bumper 14 22428 Outside Door Handle Large Pad 15 N621906-S2 Nut (2 Req'd) 16 N807329 Screw (3 Req'd) 17 26595 Rear Door Electric Latch Actuator (RH) 18 W701566-S47 Rivet 19 431C04-A Rear Door Latch Striker Assembly 20 — Door Lock Striker Plate (Part of Door Shell Assy) 21 W525172-S Rivet (2 Req'd) 22 264B14 Bellcrank and Link (RH) 23 264A50 Bushing 24 N802034-SG Rivet 25 26420 Rear Door Latch Control Rod Link 26 W525172-S Rivet (2 Req'd) 27 21818 RR Door Latch (Inside) 28 A26460 RR Door Latch Push Button Rod 29 21982 Door Latch Rear Striker Assembly 30 N808377-S101 Screw (2 Req'd) 31 250A04 Rear Door Catch 32 N801010-S100 Truss Head Bolt (2 Req'd) 33 N804234-S2 Screw 34 266A74 Rear Door Latch Actuator Retainer 35 24630 Rear Door 36 26552 Rear Door Latch Control Escutcheon A — Tighten to 21-29 Nm (16-21 Lb-Ft) B — Tighten to 10-13 Nm (89-115 Lb-In) C — Tighten to 7-8 Nm (62-70 Lb-In) D — Tighten to 26-34 Nm (20-25 Lb-Ft) E — Tighten to 3-4 Nm (27-35 Lb-In)
Mar 24, 2009 | 1997 Lincoln Continental
Hardware & Accessories Logo
1,053 people viewed this question
Top Amerock Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you an Amerock Hardware and Accessory Expert? Answer questions, earn points and help others
