Question about Nespresso C190 Espresso Machine
How do I unscrew nozzle? it is stuck - Nespresso C190 Espresso Machine
Spray not working, doesn't stop water from faucet.
It sounds like a kinked hose under the sink or a clogged nozzle. Unscrew the nozzle from the sprayer and check for calcium buildup. New parts can be purchased cheaply from the local hardware store, take the old parts in and a sales rep can help you with the correct parts. Some sprayers have replacement nozzles...unscrew the old and screw in the new.
Sep 20, 2015 | Plumbing
Need assembly instruction for gaggia titanium steam wand. doesnt seem to go far enough up the tube after i cleaned it
Slide the large sleeve off, now you have just the shorter plastic nozzle with the rounded cap. Unscrew that cap - hold the plastic nozzle with one hand while twisting the cap to unscrew it.
Inside is a hard plastic ring and a soft rubber sleeve. Sometimes the soft rubber sleeve will not come out of the nozzle - if so then just leave it in - but if it will come out, take it out and clean everything really well.
OK ... now put the cap on the steam pipe, then the hard plastic ring, then the rubber sleeve - and slide them up high enough on the pipe - then slide on the nozzle last. Then tighten the cap down on the nozzle until it is gripping good and tight. Then slide the long outer sleeve and you should be good to go.
Oct 01, 2010 | Gaggia Titanium Espresso Machine
Can't unscrew nozzle from hose what do I do to loosen?
I used a vise and pipe wrench to loosen. Have to be careful with the vise that you don't over tighten it and damage the hose fitting. When replacing the nozzle, lube the threads with non-water soluble grease.
Apr 27, 2010 | Northstar Pressure Washer Turbo Nozzle
I have a Mi T M job pro 3500psi pressure washer that may have a clog in the nozzle, how do I release the pressure in the line? All the pressure fittings are stuck (probably from the pressure in the line),...
If the engine is off, try unscrewing the hose at the pump. Put on a thick pair of gloves and start to unscrew slowly till you feel some preasure escaping. It should release quickly. You can use a piece of wire brush wire to unplug the nozzle. Wear safety glasses while performing this task, and expect it to happen again. Good Luck Friend.
Feb 07, 2018 | Mi T M WP-2700-4MHB Pressure Washer
LEFT(DRIVER SIDE)WASHER SPRAYER NOT WORKING. WHAT
The sprayer nozzle is clogged, first try cleaning it with a very thin pin, if still it doesn't work, you can install a new one, all you need to do is press the side clips of the sprinkler ( under the hood ) and it easily pops up and pull it out ( top of the hood ).
Feb 08, 2010 | 1999 GMC Suburban
Hiya, We have a tricity bendix 1000rpm cwd1010 & i'm having problems getting to the filter to clean it.I have opened the door on the bottom right of the machine & have attempted to unscrew the...
It will be something stuck in the filter that is preventing it coming out.
As you unscrew it try twisting it from side to side , and screwing it back in again, and keep on doing that, hopefully it will eventually come out.
Hope this helps.
Jan 12, 2010 | Tricity Bendix Washing Machines
Stuck
You need to purchase new tips. They go bad after awhile. They're made of copper, and are quite soft. Simply remove the nozzle (piece covering the tip)by unscrewing it, then get a good set of pliers on the tip to unscrew it. When screwing the new tip in, be sure to only finger tighten it, if you put too much force on it with pliers and what not, you can damage the softmetal, and end up with the same problem.
Oct 16, 2008 | Lincoln Electric LINK2400-+1 CV-305 MIG...
Mig replace tip
Pull off the extreme outer nozzle of the MIG gun. Clean the inside of this nozzle with MIG pliers or round wire brush. Unscrew the welding tip. (If it is stuck, try using a pair of pliers lightly). Clean the entire area with a regular wire brush. Screw on the new tip finger tight, but snug. Replace the outer nozzle.
Aug 27, 2008 | Lincoln Electric LINK2400-+2 CV-305 MIG...
PHV1800 nozzle fixation
yes i can see it, and according to that, heres my answer
you can try pulling harder.. or use the screwdriver as a lever... it doesn't make sense that if you unscrew everything, you cant pull it out, so maybe its something tats a bit stucked
Jan 08, 2008 | Black & Decker PHV1800 Bagless Handheld...
No steam release
I solved the problem, the metal (hot!) release rod gets stuck & needs a little push.
Unfasten the top by prying off the rubber gasket after removing the top. Remove the 2 small phillips screws, then remove the front that holds the nozzle, & remove those 2 phillips screws.
Carefully pry up the top with a putty knife, inside you will see the tip of a metal piston that the plastic release knob is supposed to contact. Set it on its front, & soak the piston with a light household or sewing oil, giving it a few taps with a blunt object occassionaly to loosen, heat up & test before reassembling, but remember, the piston is very hot. When you push on the piston with a screwdriver, it should release the steam, but also stop when you let go. Work with it a little & it will come back to life.
Dec 12, 2006 | Euro-Pro Super SC710Z Steam Vacuum
Nespresso C190 Espresso Machine Logo
105 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Michael Thomas
Michael Thomas
Colin Stickland
Colin Stickland
NOEL
NOEL
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
