Error code E16 on display
SOURCE: bosch washing machine error code
I've had the same problem, when we had a power cut I opened the door and after that I could only got F21 flashing! ,I googled for the answer and this WORKED:
Turn programme switch to 6 o clock,hold RPM button turn switch to spin, release RPM button
SOURCE: I have E3 error code on a Bosch washing machine
"E3" on a Bosch Maxx means the door is not closed properly. Either there something preventing it from closing properly (blockage) or there is a fault with the locking mechanism.
SOURCE: error code F 21
I have a Bosch Classixx 6 1200 express washing machine showing error code F21 on the display, what is it?
SOURCE: My Bosch washing machine (logixx
F37 is because of operating the unit below specified temperatures.
Pressing the temperature button twice shows a snowflake and sets a defrost function.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: I have an error code
Hello there
Normally this is a drainage problem code
Unplug the machine and wait for 30 min
During this time Remove the cover on the front bottom right corner or the front cover at the bottom , use the small hose that is attached to the pump to
drain the water, from the pump then unscrew the large drain cover and remove the
blockage from the drain pump. and any additional hoses then reattach the hoses and then plug in after the 30 minutes is up then press the cancel button and test ...Test by pouring 1L water into section II
in the top and setting the machine to 'drain'. it should beging to drain
