SOURCE: Sony Bravia KDL-V40XBR1, no picture
You either have failed 24vdc power supply section or failed backlight inverter board, check for 24vdc first, look for caps with leaking/bulging top.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Sony+BRAVIA+KDL+-V40XBR1+
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
SOURCE: Can not change the channels on my Sony Bravia
Is this the original remote or a universal remote? Can you change the channel with the buttons on the right side of the TV?
Can you type in a channel number and go to that channel? (this applies if the channel will not change with the buttons on the TV.) Try to
rescan the channels (it could be that the TV has the other channels
hidden (or lost the list).
If it is a universal remote, you may not have the correct code (just a close one). Try additional codes for Sony TVs. Also when was the remote built? If it was programmed more than 6 months before the TV was released, then it will not have the correct codes. You would need a newer remote. A substitute remote can be obtained from https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?sessionId=4q4-Cd8shqFs_c5rcVcD_Lw or http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=KDL-V32XBR1&uuid=12842263276080 .
I hope this helps.
SOURCE: Sony bravia v series 32"
hi,
IT normally happens after factory reset is done. You need to reprogram the channels. Try the auto program (AUTO TUNING) Process.
SOURCE: "Guide" button makes Sony Bravia TV go to black screen
I am having the same problem with my newish Sony Bravia. There is only a black screen when I use the "GUIDE" button. And individual channels show "No program description".
Did you ever figure out the problem?
Thanks.
SOURCE: TV will not remember settings Sony Bravia KDL 40S4011
Probably you are in "shop" mode of TV. Try to reset your TV and go through initial setup. Most important - choose "home" instead of "shop" when asked during initial setup. Resetting - keep up arrow pressed and switch of TV. Keep the button pressed when TV automatically switch back on. This will reset TV to factory defaults.
