Dell Dimension 2400 PC Desktop Logo
Posted on Jul 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Won't boot from dvd rom (I'm trying to install Ubuntu Linux)
Robert Stout
Level 2:
  • Expert 222 Answers
  • Posted on Jul 08, 2009
Robert Stout
Expert
Level 2:
Answers
222
Questions
Helped
69368
Points
698
If your system has one optical drive, press F12 when the Dell screen comes up at boot. then select the drive...
If you have more than one optical drive, the master is the only one that can boot(per Dell).
If the above (F12) does not work, you can try changing the boot order in the BIOS to:
First--CD/DVD
Second--IDE-0 (hard drive)
Third--(any other devices)
Unable to upgrade it to Window-10 for Gateway DX4885. It throws an error while installing the update
Copy and paste the following link into your web browser:
https://www.alphr.com/upgrade-windows-8-1-to-windows-10/
Windows 8 is 'old hat' now and you may have difficulty in upgrading, if it is actually still possible.
Your computer is old? There's (old) 32 bit computers and more modern 64 bit computers. An operating system is designed for either 32 bit or 64 bit.
What you can try is another OS such as Linux. Run it as a 'live version' to see if you like it before you install/use it. All you need is a usb drive or dvd that can be written to.
1. Download rufus
https://rufus.en.lo4d.com/windows
2. Download a Linux iso image - such as Desktop Ubuntu (it will download into the downloads folder)
https://ubuntu.com/#download
3. Insert the USB drive into your computer
4.Open rufus - navigate to the download folder and install Ubuntu onto the USB drive. (simply copying and pasting the files will NOT work. You have to make a bootable USB. Rufus does this for you.
You now have a portable OS on a USB.
5. Restart your PC and open the bios settings. Navigate to the boot sequence and change the first boot device to USB. Press F10 and exit. Your PC will then restart and run Linux from the USB. No changes are made to your computer.
You can either run Linux 'live' from USB or click on the desktop icon which says install onto computer.
If you wish - instead of putting Linux Ubuntu onto USB you can burn the downloaded .iso file onto dvd and choose cd/dvd drive as first boot device.
Again, simply copying and pasting the Linux image onto dvd will not work. You must make it bootable. I you don't have the software try installing k3b:
https://sourceforge.net/projects/k3b/
It's all actually quite easy to do.
Can I override the bios at startup so that it will recognize a new hard drive - for linux?
There should be no need to play around with your bios settings. Linux will install on a brand new hard drive as the sole operating system, or on an existing hard drive alongside Windows without any problem.
If you haven't already got a Linux distro, have a look at
http://www.ubuntu.com/download/desktop
Download whichever version of Ubuntu you prefer (LTS- the long term support version is recommended).
When the .iso file containing the operating system had downloaded, burn it onto a dvd, or install it on a usb drive.
Insert the dvd into the drive and restart or switch off/switch on the computer. The dvd will then kick in and offer you the choice of trying Ubuntu without installing, or a full install.
If you're using a new, empty hard drive just follow the on screen instructions and Ubuntu will install as the sole operating system.
If you already have Windows on your hard drive Ubuntu will give you the choice of either erasing Windows or installing Ubuntu alongside Windows. It's your choice.
Installing Ubuntu alongside Windows creates a dual boot hard drive. At start up you just choose which OS to use - Windows or Ubuntu. If creating this dual-boot system Ubuntu puts a (Linux) boot loader into the Windows OS so that Linux is recognised.
If you save the Ubuntu file to a usb drive you then have to change the bios settings so that your computer uses USB as the first boot device. Then restart your computer so that it boots in from your usb .. and Ubuntu will begin installing.
Whichever you use - dvd or usb - during the installation process Ubuntu will ask you how many GB of hard drive space it should use? You do not need to physically partition the hard drive. Linux will do it for you.
If it's a desktop PC you are using with Windows on the first hard drive and are fitting a second hard drive to install Linux on, or have installed Linux on the second hard drive .. and find that Linux doesn't appear at start up, it's because there's no Linux boot loader in Windows.
I quit using Windows many years ago.
1helpful
How do i install a operating system on a sony old sony viao 600hep with no dos and no operating system and a broken cd rom drive. only have usb.
Check out this:
http://www.ubuntu.com/download/desktop/create-a-usb-stick-on-windows
This gives instructions on how to download, and create a ubuntu bootable USB stick.
http://www.ubuntu.com/download/desktop/try-ubuntu-before-you-install
This will give instructiosn on how to load and install from said USB.
You will need:
A working computer with Windows
A 2GB or larger USB stick
Internet connection
After you've made your USB stick, when booting up the computer you wish to install ubuntu on be sure you have the USB stick inserted when powering it on. When the start screen comes up press ESC to enter the BIOS or boot order. Select the USB stick from within the BIOS boot order menu, or the USB stick from the boot options menu.
Load ubuntu, install, enjoy.
How to booting from cd rom on hp compaq 6710b and install ubuntu
Press F9 at startup. This will give you your boot menu. You will then be able to boot from your dvd-rom / upgrade bay etc. 27bd1b34-d4db-4891-9414-81770f593217.jpg
Toshiba satellite M45-S169 won't boot ubuntu from DVD
Your really pushing the lower minimum requirement limits if you're trying to use Ubuntu 11 or Ubuntu 12. Especially with your on-board graphics chip which borrows system ram.
Try Ubuntu 10.04.4 LTS (Lucid Lynx) instead.
Go Here and download the 1st link on the list under Desktop CD:
http://releases.ubuntu.com/lucid/
OR...
Here is a direct link to the ISO file you need to download and then burn to a CD:
http://releases.ubuntu.com/lucid/ubuntu-10.04.4-desktop-i386.iso
If you don't have Software for burning iso's to CD's then download and install this totally FREE CD Burning program:
http://download.imgburn.com/SetupImgBurn_2.5.7.0.exe
Ok I have a Gateway Laptop model NV73A06u and it is not powering on. The computer is no booting up correctly. I tries to start and then fails. The computer tries to fix itself for a long time and nothing...
Have you tried a Live CD?
Since you have a newer model, you can try the latest Ubuntu release located here.
Download the .iso file.
http://www.ubuntu.com/desktop/get-ubuntu/download
Burn the .iso file to a CD or DVD.
For burning .iso files to media, I like ImgBurn for Windows ( http://www.softpedia.com/dyn-postdownload.php?p=27810&t=4&i=1 ) and plain K3B for Linux.
Once the disk is burned, pop it in and make your machine boot from the Optical Drive (CD/DVD Drive).
Hit enter a few times once you are asked about the preferred language and to try Ubuntu without changes to your computer.
From there it should either boot up okay (maybe without sound because sound is iffy in Linux) or it will continue to be all kinds of badness.
The thing is at this point you should be able to tell if it is most likely hardware or software. If Linux boots up off of your disk, your Windows installation is hosed (not so bad, possibly cheap to fix). If you can't even boot into a Linux live environment, then the fix may involve money and a fair amount of screwdriver action.
-Brad Chesney
http://rustbeltrebellion.com
3helpful
2answers
Install Ubuntu
Make sure the computer starts from the cd drive.
see this page for instructions on changing the boot order
http://www.whitecanyon.com/how-to-change-boot-order.php
ones the boot order is set properly insert the cd in the drive and restart the computer.
ubuntu cd/dvd will load and give you some options on the screen, follow the prompts to install ubuntu.
if you need more help read the ubuntu documentation
https://help.ubuntu.com/community/Installation
if the above link is broken try
http://help.ubuntu.com/community/Installation
DELL Demension 8300 PC, cannot boot from cd rom
try ubuntu which is a good version of linux,search on google..Now if you really want to install another o/s then you need to change BIOS setting to boot from cd first on start up screen.For most pcs it;s normally a delete or F2 button but hace a look at boot up it will say something like press del or F2 to change...
1helpful
3answers
Dual Boot Ubuntu
1st, install windows or if you have already its good .
Then, download Linux distribution that suits You better
Download It and burn into a CD or DVD with ISO file you can use Magic ISO or other manufacturer
then Go to BIOS setup and set 1st priority is the CD or DVD drive and save and exit
and install follow the instruction of linux.
also if you chose capacity of windows or linux is to little dont worry you can make install a partition magic and resize what you like....
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
