Question about Brother HL 1440 Laser Printer
Brother HL1440 can it be set up to print lighter so we use less toner. Thanks
garyab9ss
    Novelist:
  • 140 Answers
You can set the Toner Save setting in the printer properties tab of your printer in the Windows or MAC environment. Your user manual does show where they are located. http://download.brother.com/welcome/doc002127/ZLe_UG_eng.pdf You can try this link to download the user manual from the Brother's website. It is a free PDF download.
Posted on Mar 01, 2015
Brother HL1440 has dirty lines on copy how can I clean. Is there something I can buy I am not mechanically inclined.
its the drum or the toner. if you have an old toner run a test with it. If it clears up its the toner cartridge. If not its the drum unit. I sell the toner cartridges for 40 and drum for 65. Steven 818-888-0006
Mar 10, 2010 | Brother HL 1440 Laser Printer
Where to find "toner save mode" ????
You can save toner using this feature. When
you set toner save to On, print appears
lighter. The default setting is Off.
a Press Menu, 1, 6, 1.
Ecology
1.Toner Save
b Press a or b to choose On or Off.
Press OK.
c Press Stop/Exit.
Hope this helps
John
Nov 20, 2009 | Brother MFC 7840W Printer
My HL 1440 Laser printer does not print The
If your printer have no paper jam inside and paper tray has paper in it, then you need to replace toner cartridge.
Oct 06, 2009 | Brother HL 1440 Laser Printer
Low print quality
It depends upon the number of prints you have done since Feb and the toner cartridge capacity. Some toner cartridges have 2500 page capacity others have 5000 pages or more.
If you think you have not exceeded or reached the cartridge capacity, take it out of the printer and give it a shake in a horizontal position to distribute the toner evenly across the drum and place it back in the printer. This also works when the toner is nearly empty.
Sep 09, 2009 | Brother HL 1440 Laser Printer
Black smudging on all the page from hl1440-brother
  • Turn off the printer.
  • Take the toner off.
  • Shake the toner for 4-5 times.
  • Install it back.
  • Then try to print.
Thanks, CF
Jun 17, 2009 | Brother HL 1440 Laser Printer
I have a Brother HL1440 and just changed the toner. Now it prints with three very wide black line with a thin white line in the middle (where there isn't any ink). It might be something that rolls in the...
Since you just changed the toner, more then likely it's going to be a defective toner. To test this you can either reinstall the old toner and try that and the lines should go away. If you don't have another toner to try, pull that toner out and open the shutter that exposes a metalic looking roller, If this is nice and clean then it's good and more then likely it will be a fuser issue but if you can see the lines on the drum then you know it's defective and you should be able to get a replacement from where ever you bought it... Hope this helps out, please mark it a fixya if this helped...
Jan 20, 2009 | Brother HL 1440 Laser Printer
Light fax
This could be a couple of different things. The first is that you are running out of ink or toner. Or you could have your toner save turned on. You can conserve toner using this feature.
When you set Toner Save to On, print
appears lighter. The default setting is Off.
1 Press Menu/Set, 1, 6, 1.
2 Press ▲ or ▼ to select On (or Off).
Press Menu/Set.
3 Press Stop/Exit.
Jan 13, 2009 | Brother IntelliFAX 2800 Laser Fax
Brother HL-1440 Not working
Toner is MT.
see what do my do my lights mean in Wiki manual.
Nov 06, 2007 | Brother HL 1440 Laser Printer
Brother HL 1440 Laser Printer Logo
65 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
