smgez this is a minor software error, so do the reset factory settings bu device settings, it will solve your problem,if my answer was helpful please rate it. if you have any difficulty post comments and also which model are you using so i can guide you better.Best of luck.
sir is it blinks with white screen only or blinks with white screen then shut down? -if the phone can receive/send text and mms messages while the incoming and outgoing calls become shut down,i think you need to replace the battery because it is weak.use only original battery. -and if it is blink with white screen only try to reset all settings or reformat your phone,if not work hardware problem go to repair shop.
When you set your fax machine to answer on a certain number of rings it will answer it on that number of rings expecting it to be another fax machine. If you do not answer it before the aloted number of rings you will not be able to talk since the fax machine will be trying to talk in computer speak. To help you may want to set it to answer after more rings.
