Question about HP Pavilion 515n (DC471A#ABA) PC Desktop
I have a hp pavilion 515n desktop computer and was wondering how to get the password for the wifi.
Posted by Ettajean Brewer on
Cal Martin
    Master:
  • 238 Answers
Hi Ettajean,
The wireless password can be located either on the wireless router itself (if it's being provided to you by your ISP), or you'll need to log into your router to view/change your wireless password.
If you've connected to the wireless router before and simply need to recall the password, you can view it inside of Windows:
http://www.microsoft.com/surface/en-ca/support/networking-and-connectivity/how-to-find-your-wireless-network-password
If you can post the model number of your router, I can provide you with some additional direction.
Hope this helps!
Posted on Mar 01, 2015
How do I increase FSB past its factory preset in my HP Pavilion 515n pc?
Some people, when their computer reaches the point that it can't run the programs it once used to, decide to toss their machine and invest in a new one. Others squeak out some extra life by overclocking their processors. While this is ideally done with hardware, for pre-built HP computers you will have to use a software option. With this minor exception, the process is still a breeze.
Download and install CPU overclocking software, such as ClockGen, SetFSB or SysTool (see Below). http://files.extremeoverclocking.com/file.php?f=189 http://www.softpedia.com/get/System/Benchmarks/SetFSB.shtml http://www.techpowerup.com/systool/ While all these programs more or less work the same, for this guide we will be working with ClockGen. Boot the CPU overclocking software. Do not be alarmed if your computer momentarily slows down, as the software is reading your CPU's clock speeds. Click "PLL Control" or the equivalent in your overclocking software. This will show you several sliders for your front-side bus (FSB) and, in many cases, your PCI cards. Adjust the FSB slider. Be sure to do this slowly, as the processor will likely fail if there is a sudden speed change. For best results, use the arrows to slowly adjust the settings by one-to-two megahertz at a time. Click "Apply" frequently to set the speeds. Hope this helps.
1helpful
My HP Pavilion 515n pc will not restart without pressing the F2 key, why?
Message was "press F2 to continue". This happens when there are errors in the boot up process like:
CMOS settings incorrrect
Date/Time incorrect
Missing drive
First to replace should be the CMOS battery inside the computer.
I cant get a microphone to work on my computer
Download bios update from the HP support website. Install it on your computer. That should work.
However, if you could give me more information, I will be able to help you more.
BIOS UPDATE .
How do you get the roller out?
I dont know if I have U correctly here.. but if I think what ur trying to ask here.. then click the following link for detailed instructions.. http://tinyurl.com/RollerOut
What replacement backup battery does the pavilion
Hi, most motherboards that I have fixed etc... have used the 3.0V CR1620 Button Cell Battery which is easily available and cheap!
Sound isnt working on computer
try reinstalling the audio driver..
that should solve your problem
also try to see if te windows audio service is running or not
through
run->services.msc
check for windows audio
if it does not solve please message back
1helpful
2answers
Loud fan noise
have one very similar, they only have a fan in the power supply, and a small, small fan on the CPU. If it's the fan in the power supply making the noise, some people would say replace the whole unit, some would say replace the fan. I would replace the fan, but if you don't want to take the risk of getting electrocuted, that's probably a great idea. A power supply can be found somewhat cheaply, but one that fits those cases might not be quite as easy.
2answers
HP pavilion 515n runs real slow
Yes, you can add more - But if you have a fragmented HDD, it won't help much. Before you spend money on physical memory, I would do a disk defrag, check to make sure your HDD is not getting too full, and check your virtual memory. On xp you can get to this by right clicking MY COMPUTER, click properties, Performance, Paging file. XP has a problem during install of not setting this right. Change it to "system managed size", apply & ok, reboot your computer. If this doesn't help, and your HDD is not too full, stop some of the things that are loading up on startup.
Can this HP access internet wirelessly?
you need to add a wireless card inside your computer or else you can stick in an external USB wireless in one of your USB slots. then you will be good to go.
How can I find out if my HP 515n already has card for wireless?
To see what is installed on your windows XP machine.
Right click on "My Computer". Left click on "Manage". When the window pops up left click on "Device Manager".
This list will show you what hardware is detected by the Operating System.
Hope that helps.
Please rate me.
Thank you
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/rick_eeed4a91077c64e8
HP Pavilion 515n (DC471A#ABA) PC Desktop Logo
Top HP Computers & Internet Experts
Ekse
Michael Thomas
Michael Thomas
Mandeep  Singh
Mandeep Singh
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
