the only thing you can do is adjust your brightness, contrast, sharpness controls. every station is different especially the sound is louder on some channels and lower on some.
try adjusting your brightness a little highter up and if you have a LCD tv you can adjust the backlight through your picture/video/image settings in your On Screen Display menu to your television
Most likely you have the opc feture on. go to the menu under picture setting first option should be to turn on or off the opc. turn it of and should solve the problem.
Yes it could be other things, but to be honest, I wouldn't waste time or money on a set that old. If the picture was perfect and something else went bad, perhaps a small investment would be worth it, but with your description, I'd pass.
try to open your tv and you can find the flyback ,in flyback you can see the screen and focus to adjust.use and try to rotate the screen,it control the brightness of your unit
You are going to need the assistance of a servicer for this problem,I suggest not to use it until it gets repaired ,shop around for an estimate ,tell them what the symptom is they might tell you about how much it might cost,is hard to tell without measuring some voltages.Be safe and call for help.
The Picture tubes(not bulbs) do and probably are weak. There replace should only be done by a trained service person. One reason would be the hI Voltage issues related to the crt's, as these tubes store alot of HI voltage even after its unplugged for a while, and another reason would be that these tube can very easy implode then explode and that wouldnt be a pretty sight. Third would be the alighnment involved after all three tubes are replace. There ba cross hatch generator and alot of time involved with the alighnment. Please seek a pro to assit you when your ready to spend at least 900 TO 1000 bucks. Good Luck
When you are photographing scenes with mostly light objects (for example, snow, water, and sand), the picture is usually underexposed (darker than it really is). The camera meter registers the brightness of the scene and tries to set the camera lens and aperture for an exposure based on average brightness levels (18% reflectance) causing it to underexpose, as in the following picture.
When you are photographing scenes with mostly dark objects (for example, shade, shadow, and overcast skies), and very few light objects, the camera may overexpose the image, causing it to be too light. If you have a flash on your camera, you can compensate by adding "fill flash" for some extra light.
If your camera has an exposure compensation adjustment, you can increase or decrease the exposure to correct for these exposure problems. Increase the number to make the image lighter, and decrease the number to make the image darker. You may want to try a series of shots with different exposure compensation adjustments to get a feel for how much difference these adjustments make.
