Microwave Ovens Logo
Question about Microwave Ovens
What is the reason for high voltage fuse to blow outon microwave.
Lamona microwave model Hja 7020
John Snow
    President:
  • 788 Answers
The only reason for any fuse to "blow" open is a direct short. The most common reason, in a microwave oven, is the Magnetron. This is the device that generates the microwaves. If this is the case, repair is not very economical.
If you have a volt meter or a device that can check for resistance, check for anything that is shorted or "0" Ohms to ground.
I hope that his helps answer your question.
If you have any further questions please feel free to ask.
Posted on Mar 01, 2015
Whirlpool microwave fuse has blown multiple times
It depends on which fuse and when it blows. Wish you had mentioned that.
But usually it's a defective door switch or door switch mount.
If the fuse blows at random times while it's cooking, it may just be a loose fuse holder. Those have to be replaced due to metal fatigue, not just squeezed tight with pliers.
If it blows as soon as you hit "Start" to begin cooking, you have a shorting high voltage capacitor.
If it blows when you open or close the door, you have a loose or defective door switch or latch.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Microwave keeps blowing fuse
There are three possibilities, a bad magnetron, high voltage capacitor, and diode. In rare cases the high voltage transformer will be an issue but unlikely, if the microwave oven is more than 5 years old consideration should be given in replacement.
Have power at the outlet, nothing to the unit. worked fine last night. no clock no child reset not nothing. is there a fuse somewhere or a safety device?
There is a main fuse in the microwave oven, it is located under the keypad near the high voltage capacitor "silver and rectangular in shape" make sure unit is unplugged and dis-charge the high voltage capacitor for safety. I find the reason in most cases, that the fuse will blow if there is a defective door switch.
Kenmore Micro/Oven fuse keeps blowing
Disconnect the connector to the primary winding of the high voltage transformer. Put a new fuse . If the fuse is not blowing the problem may be in the secondary side of the high voltage transformer. Chek the highvoltage diode, capacitor, magnetron respectively. you can also check the primary winding of the low voltage transformer.
Microwave emerson not turning ON
That makes it sound like a bad high voltage transformer.
Do you detect any burning smell?
Do the windings of the high voltage transformer seem blued or blackened?
They should be copper colored or maybe a little darker due to the varnish.
Sharp R-9H66C Microwave Convection blowing fuses
check high voltage transformer and high voltage diodes, condencer, and magnetron.,
Whirlpool Microwave Model MH6130EQ0
If the fuse blows as soon as you hit START, then it's likely that you have a shorted high-voltage capacitor. If the fuse blows a few seconds after you hit START, then it's likely that you have an overheating / shorting high-voltage transformer. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
1helpful
Replace fuse
The fuse is generally located on the bottom of the chassis of the microwave. You have to remove the outer cover on a counter top model - or the front panel assembly on an over-the-range model. There are several reasons why it may blow. If the fuse is loose in the holder, the fuse and the holder should both be replaced. If - with the microwave disconnected from the wall - you can easily turn the fuse with your fingers while it's in the holder, then it's too loose. What happens is the loose connection generates too much heat, causing it to melt internally. If so, you'll usually see a ball of solder at a point where the cap meets the body of the fuse. If the fuse blows as soon as you plug the oven in the wall, or when you open the door, the problem is likely with the door switches. You can find my files "doorsw.txt" and "safety'txt" via Google. They give you the safety warnings and cover the diagnosis and replacement of the door switches. If the fuse blows as soon as you hit START, then it's likely that you have a shorted high-voltage capacitor. If the fuse blows a few seconds after you hit START, then it's likely that you have an overheating / shorting high-voltage transformer. If you still have a problem, please wirte back with more detail. Be safe!
Top Microwave Ovens Experts
Marvin
Marvin
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
