F63 means "Water path control unit fault". This is the unit on top of the detergent compartment, which directs the incoming water to the appropriate compartment. Mostly this error is not serious and does not prevent your machine from doing its work. If it does, it could be a connector or corrosion on the little PCB that's within the control unit, or maybe even on the main electronic (depending on your model). See Miele goedkoop repareren cheap repair preiswerte Reparature
