SOURCE: keeps switching off
Theres an power supply upgrade that Pioneer extended on most of their plasma models, even after your warranty is up. Contact them it cant hurt to try
SOURCE: 61 inch pioneer plasma audio hook up?
I checked on Pioneer's site and couldn't find literature for this model, but did find the product information sheet for a model PDP-614MX. It may be similar, but no promises. This model has no audio output available, but does accept several audio inputs. It shows speaker terminals on the bottom and claims a 9-watt output for each channel. Speakers that mounted on the sides were available as an option.
This monster was originally designed for professional use (stores and such) as strictly an output display device. Probably the best solution would be to use this to display the video, and run the audio output from the source (DVD, satellite receiver, etc.) to a separate amplifier to drive your speakers.
SOURCE: I have a problem with
How are you getting the sound to your sound system? Basic LCD monitor and LCD TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide Failed TV, Monitors, Caps : http://s807.photobucket.com/albums/yy352/budm/ Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
HDMI? ANALOG AUDIO LINE OUT RED and WHITE RCAs? TOSLINK optical?
How does it sound with its own built-in TV speakers?
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series.
SOURCE: best plasma TV HDMI
None.All Plasma tvs designs are alway have high heat output and consume alot more A/C power energy than any other tvs designs out there.Tvs like CRT-tube tvs,DLP tvs -Projection tubes and projection lamps tvs,LCD-flourescent tubes tvs as Liquid crystal display screen tvs.All these tvs designs are all good tvs designs to buy but the pictures display and screen lighting and the sharpness of the pictures never have and able to compare high enough qualities as a display picture on the screen output to a Plasma screen tvs,until now LED-tvs are LCD and LED screen display combine to make it better and brighter technologies and now are good enough to compare to a Plasma screen panel tv.So buy a LED tv will get less heat output and comsume less A/C power energy too and it is good enough pictures qualities too.To compare too as a plasma screen panel tvs output.
SOURCE: how do i hook my dvd player to my jvc 32 inch flat screen tv
U might be putting them in the wrong places or the wrong channel try and go through the channels but make sure they are hooked up right cause it will mess the TV up I did it on time and had to go get me another one cause I messed the sound up Hope this helps ya
