Question about Measuring Tools & Sensors
I have changed the batteries in my station multiple times. Bought new batteries and the station will work for a short time and then go blank. Help!
I have followed the directions in the manual and the station will work for a few minutes and then goes blank.
Frank Perretto
    New Friend:
  • 23 Answers
Have you tried to move the sensor closer to the station ?
Posted on Mar 01, 2015
Testimonial: "I've been within 10ft of the sensor and about 40ft; too no effect."
  • Frank Perretto
    Frank Perretto Mar 17, 2015
    Sorry the only other thing I can think of in the maual you have to place the battieries in the unit and then the sensor and keep them face to face till they adjust , once then you can move your sensor to a proper location I believe it states this in the owners manual if you do not have one you should be able to obtain one on line or call the Oregon Scientific directly with your issue you may have a deffective unit ?
I have an Orbit 4 station timer, I've tried to reset / program several times. The problem is it repeats each station 2 times.
sounds like you have multiple start times. unplug, remove battery after 5 minutes plug transformer back in and install battery. If unit is ne return it
May 30, 2017 | Orbit Hardware & Accessories
After an oil change the touchscreen on the navigation/radio/bluetooth is not responsive? How do you fix this issue?
I have no clue what changing the oil would have to do with any of this. However, the problem you are describing sounds a lot like the types of problems that occur with a shorted battery cell. I would take a HARD look at the battery and charging system. If your battery is more than 4 years old, it is time to replace it.
If the battery and/or charging system is the cause, you will also very likely have fault codes stored in several of your computer modules. You will have to clear all of these codes from all modules and force a "clean boot" of your computer network to get everything working properly.
Dec 23, 2011 | 2005 Cadillac STS
My HJ720IT pedometer screen is blank. I thought the battery had died but got a new battery and it still won't work.
Mine has same problem. Died a week ago. Put in new battery and it worked for a week. Now it is dead again.
Dec 23, 2009 | Omron Hj 720ITC Advanced Pocket Pedometer
My vigoro water timer i bought at home depot will not stay on manual off/om or on its program. I have installed the new 9 volt battery correctly since i can program ok but it shuts off in a short time...
I have a Vigoro 271-687 in which has worked well except when i change the batteries it wont reset and will not work do you have any solutions to this problem i really like this product just dont understand the prob
Jul 01, 2009 | Garden
Battery Problems with 2001 Dodge Stratus
sounds like your alternator is bad have it tested to see
Nov 22, 2008 | 2001 Dodge Stratus
Skyscan Atomic Clock WWVB
figure out where yu are north south west east zones on your map from where yu are , then pull battery again it should stop at for eight or twelve push time zone then set in a window facing your zone it should automatically pick it up shortly in awhile
sw i think it may stop at four also but then wait
Oct 14, 2008 | SkyScan 86709 Atomic Wall Clock
Brand new batteries and its tellin me to change them!
please check if the batteries u used before have leaked any oil inside the camera. this damages the metal strip that shorts and two batteries. if there is no damage then tat portion s safe.
the small battery inside battery compartment is for camera date. dont disturb it.
after changing new batteries tha camera works for few time and then shuts down means your camera CCD s consuming lot of power. use a camera adapter to confirm that the camera works in normal power atleast.
even after this. camera shuts off itself. take it to service centre soon.
Nov 25, 2007 | Canon PowerShot A520 Digital Camera
Start and die
Could be time for a new camera But check out Kodak Support first. It has been said that cameras in a certain price band[any make/model] are to be considered as disposable -like toasters and kettles I guess.
Aug 22, 2007 | Kodak EasyShare DX6440 Digital Camera
Measuring Tools & Sensors Logo
293 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
