Question about LG Computers & Internet
I have LG E500 and I want to instal XP. I cant make changes in bios like boot sequence, so I cant boot from cd and therefor I cant instal XP. What should I do?
Posted by mirtom86 on
Anonymous
  • 112 Answers
I don't recommend downgrading your laptop from Vista to XP but...
According to manual, pressing F2 during boot sequence takes you to BIOS and then you can change
the order of the boot sequence in the BIOS. From the manual:
"...set passwords, change the booting order, and add new peripheral devices to the machine."
If you can't find boot sequence in BIOS setup, talk to a support rep online:
http://ca.lgservice.com/index_b2c.jsp
You may need to use a different server if not in CA.
Posted on Jul 08, 2009
I have a toshiba 440cdt, cant remember password, it also wont boot from cd? i have held esc then f1 to get into bios and changed boot sequence to cd 1st, but still cant boot from cd or get through bios...
You might have to go to Toshiba support and get a BIOS Flash to update for your BIOS. Win XP is no longer supported, therefore you may need to go to Windows 10.
Feb 06, 2018 | Toshiba Satellite Pro 490CDT Notebook
My laptop is LG X-NOTE e500 G.A2H2A2 .Present operating system is Window vista i want to load operating system xp service pack 2.plzzzzzzzzz suggest
You need to have a Windows XP SP2 bootable disc. Just go to BIOS and enable the boot from CD/DVD Insert the Windows XP disc It will boot with the bootable disc and you just need to follow the on screen instructions. You will need to format the HDD and do a clean installation which will result in data loss. Please make sure that you take a backup of all your important data files before changing the operating system.
For any further assistance please feel free to revert with comments.
Thank you for choosing Fixya
Apr 19, 2010 | LG E500 Express Dual Series Notebook PC
Xps m1330 died
does it boot ?
dead ? cant u even c anything on the screen..?
u can revice it back....if u can go into BIOS immedialty while switching on....
press DEL / F1 / F2 / Ins/ .....any one of this key to get to BIOS
look for the boot sequence...
u can make changes to make it bootable from CDROM / DVDROM
make the 1st boot seq to CDROM
then save the changes to BIOS by pressing F10...save and exit comand can also do it.
then insert the WIN xp install CD in the CD drive and swithc on again...
let it boot from the CD
if it does then u can re-format the disk and install the OS
Feb 24, 2010 | Dell XPS M1330 Laptop
Compaq armada e500
you can safely install up to a 80 GB HDD in that compaq. When getting into the bios go to the boot sequence section and change the boot squence to be CD=>HDD=>FLOPPY or FLOPPY=>CD=>HDD
Jun 02, 2009 | Compaq Armada E500 Notebook
NO BOOT OPTIONS FROM CD
simple if you need to format your system then insert the windows xp cd in a normal mode and go to installation and it will ask for the an upgrade or fresh installation select fresh installation no need to enter bios this reboots your system via cd and let youformat your machine.
Feb 17, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
I want to boot from cd to change windows from xp to 98
enter the bios set up on start up. Go to boot sequence, change 1st option to cdrom instead of main drive. Save and exit. Let it boot up, put 98 disk in cdrom. Shut down, reboot and win 98 installation will begin asking you to over write existing ops sys. Choose yes and the install should be a breeze after this. Once xp is installed, dont forget to return to the bios and change back your boot sequence to hard drive as primary /master.
Sep 26, 2008 | Compaq Computers & Internet
Compaq armada e500
The key for bios is F10 just press during compag loading screen or if dat doesnt work immeditely after. I found this out by trying all of them in sequence to see which one worked
Jun 09, 2008 | Compaq Armada E500 Notebook
Notebook won't book from CD
could you start setup from windows? if you can, do that. but the not booting from CD problem, it might just be the cd cause that's happened to me where certain cd's won't boot.
May 04, 2008 | Compaq Armada E500 Notebook
HP Cpmpaq Presario V6000
XP wont be able to detect your hdd as you are using a SATA drive. You have two options here
1. Disable SATA function in the bios (easier to do) and use again your XP cd to install the software, it should be able to detect the hdd this time around
2. You have to slip stream the SATA driver to your XP CD and recreate another CD from it. (harder to do). Google "SATA driver slipstream XP" you will be directed to the proper sites
Apr 05, 2008 | HP Compaq Presario V6000T Notebook
Boot sequence problem
try booting to DOS screen only by inserting a boot-able floppy disc (I use Win ME disc at this point although my system is also Win XP). Then select "boot with CD-ROM driver". It will detect your CDROM drive and assign a letter. Now insert the CD and boot from there. I have done this sequence many times with no problems.
Jul 13, 2007 | Compaq Armada E500 Notebook
Computers & Internet Logo
424 people viewed this question
Top LG Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
