The remote was working perfectly when I shut my TV down, but the next day when I tried to open the TV it did not work. I changed the batteries and it still did not work. The power switch on the TV itself worked fine but, once turned on, the remote would not handle any of its normal functions.
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
SOURCE: remote control train won't work
The wires will have pulled off the circuit board inside.
Remove screws (force a hex driver in there) and solder wire back on.
Train surgey (geddit) is very fiddly. Have a drink first! ;-)
SOURCE: Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
SOURCE: power up, attempts to turn on, then shuts off,
Replace the three deflection capacitors CP150, CP120 and CP114. You can get the repair kit by that same name from www.tvrepairworld.com which also contains the CD with instructions.
