Computers & Internet Logo
L
Louise Bell Posted on Feb 28, 2015
Windows 8 users manual
I did not get a users manual when I received a gift of new computer with Windows 8. How do I get one noe?
I'm in a big need for a AirTech HF-606HC (I got it as a gift and did not receive a user manual with it)
https://www.fixya.com/support/t29798532-want_air_tech_hf_606c_manual_please
8helpful
3answers
How to do if locked out of Windows 8 laptop?
1. Run "lusrmgr.msc" to reset Dell Windows password.
In Windows 8/7/Vista/XP, there is an easy way to reset a forgotten user account password by just run the lusrmgr.msc. But you need to login your server or laptop with an account which has admin privileges. Note that resetting password with this tip might cause irreversible loss of information for the user account. This data loss will occur the next time the user logs off. You should use this command only if a user has forgotten his or her password and does not have a password reset disk.
Step 1. Start your PC and log on with an available user account which has admin privileges.
Step 2. Click "start" button, press "Win+R" to open "Run box". Type in "lusrmgr.msc" and hit Enter.
Step 3. Local Users and Computers appears, all user accounts of your computer will be list, right-click your user name and select "reset password".
Step 4. Type in a new password and type it again to confirm it, click OK.
After restarting you can login that user account with new password.
2. Remove Dell password by using a Windows password recovery tool.
This is a universal way to reset forgotten Windows password on HP Server or PC, no matter what your Windows system is, Windows 8/7/vista/XP. iSunshare Windows Password Genius is designed to recover Windows password for any kinds of PC, such as hp, dell, acer, Toshiba, Lenovo, IBM etc. It not only can help reset server or laptop password Windows 8, but also Windows 7, Vista, XP and Windows 2000.
Step 1: Download and install Windows Password Genius Advanced on another computer you have access to.
Step 2: Run the software to create a Windows password recovery disk with CD/DVD or USB drive.
Step 3: Insert the Windows password recovery disk to your PC or Server and set the laptop to boot from the disk by changing devices boot order in BIOS SETUP.
Step 4: After boot from the password recovery disk, Windows password recovery tool will start automatically and display a friendly window. Then you can reset whichever account password of your PC or Server by a few clicks.
Windows Password Genius also allows user to create new admin account for your Dell Windows system without logging. With this new user, you can login your Dell computer directly and access control panel to reset other user password.
Rca tv/dvd combo says invalid input codes when i try to play a dvd
if you are talking about a older tv you need just like a computer updated codecs. or if its a bootleg it has no security code at all. and depending on age and brand, you have to rember thats where movie and singer's money came from you could down load nothing from the sky. if you have windows xp which is still the most favorite operating ststem. ddo play new Dvds you have to buy codec packages. to play new dvds, but if you have windows 7 they are aa free doen load. Just like if you own a i phone and i tunes, they noe have cloud technolagy. bi i phone haas 8 days of nusic on it and i have a ipob with 8 days of differnt songs. if you have a computer failure and lose itunes every thing u purchaced from them. the just downlod it to you itunes when you get the computer repaired. but update your i phone soft ware which at times u must they **** that nusic that may have take you well over 24 hours to tranfer from a cd. and they wont replace it its your responsability to grt it back, now they have cloud technologhy where every thing is srired in a serber some where. but i dosnt work with windows xp or rgw big fop they ade after that , u must get windows 7, also if you warch movies shot aandd produced in a differnt country they have a different countr code. but you could get luckt and the scsnner is broken or very dirty. I have Bealles Cds that i wanted to poy on i tunes. and since they were not allowed to sell the music until last year. you could not upload them greed.
I dont have the manual my MP3 104 came with because it was a gift but how can I get my computer to recognize it again Correction: Archos 104
For Windows XP users: verify the following operating system requirements are met. - Windows XP SP2 or higher - Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. - Download the hotfix from http://support.microsoft.com/kb/939211. - Run the hotfix.
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
Next:-- Refresh the driver Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. NOTE: - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Next - Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. ffffff
1helpful
Received gift of Advent Verona laptop BUT no manual with it ie user manual. We need user manual to set it up - its' O/S Windows 7 Home premium can you help? product code 450415
The Advent Verona manual can be downloaded from http://support.thetechguys.com/Uploads/%7B7bf65b24-9f32-44ce-88e4-b1bc102205b0%7D/Advent%20Verona%20User%20Manual.pdf
No user guide...
I've got a manual for the 3100 if that's any good to you?
2answers
User's Guide or Manual for Everex GA3400 Desktop Computer
I CAN PROVIDE YOU WITH THE INFORMATION YOU NEED BUT THEIR IS A CHARGE FOR MY SERVICES. PLEASE ADVICE.
Grand Canyon Tech
Grand Canyon Tech
