Question about Reddy Heater-30-55,000 BTU Variable
I have a reddy heater 40,000 btus and it works with the top off but when I put the top piece back on the fan hits it? what do I do
Douglas Jensen
  • 494 Answers
Either the fan blade is loose or the mount is loose, or the outside of the heater has been damaged/dented and hitting the blade. Leaving the top piece off is only an option if there are no pets or children around.
Posted on Mar 01, 2015
5 Related Answers
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: I just put a new fan on a R150B reddy heater and
The position of the fan is very critical to proper operation. The pressure is also very critical and if you replaced the fan you will also now have to check and adjust the pressure.
This shows how to replace the rotor.
http://www.reddyparts.com/rotor%20replacement.htm
This shows how to check and set your pressure.
http://www.reddyparts.com/pressure.htm
I also have wrote a tip that kind of summarizes everything.
http://www.fixya.com/support/r3818299-reddy_heater_troubleshooting_torpedo
Take your time and go through every step and you will get your heater back up and running again.
Heatman101
Posted on Jan 11, 2010
Anonymous
  • 188 Answers
SOURCE: REDDY HEATER 40,000 BTU KEROSENE&DIESEL
Clean your nozzel, check your fuel & air lines, you may need to replace Spark plug and filters. You can go to the manufacturers website at www.desatech.com and they offer service manuals. I hope this helps you!
Posted on Jan 28, 2010
hardrocko
Kim Yearick
  • 1476 Answers
SOURCE: Reddy Heater 55,000 has trouble igniting with top half attached
I'm assuming you mean the protective cover on the top of the unit? If so pull the back off the unit. Replace the filter. Buy a test gauge at www.reddyparts.com and set the pressure to 3.5 psi and I think your unit will run fine.Let me know how you make out.
hardrocko
Posted on Feb 07, 2010
Anonymous
  • 674 Answers
SOURCE: I also have a reddy heater 115000 btu fan spins
Make sure the all the fins (4 of them) are in the right way. I think they are longer on one side than the other. You may need to remove the black rotor and make sure the plastic insert isn't broken and check for build up on the plate behind it and the plate that you have already removed. Do not loosen the metal ring around it unless you have some feeler guages to reset the gap between the ring and the black rotor.The only thing that holds the black rotor on the shaft is the plastic insert. There also isn't very much clearance between the black rotor and the plates that is sandwiched between so it doesn't take much build up on either surface to cause a problem. One more thing, do you have the foam input filter air installed. Without it, the compressor will **** in dust, dirt or what have you and that will cause buildup around the rotor. It will also cause the rotor to break if it gets tight enough.
Posted on Jan 03, 2011
Joe A H.
  • 185 Answers
SOURCE: I have a 40,000 BTU propane reddy heater. I just
Did they over fill the tank and you are getting pure liquid to the heater..... Sounds like when you use a propane bottle hand torch and tip it up side down the flame turns orange and goes out. Also the regulator vent may have gotten plugged with dirt or ice. May try and bleed some of the propane pressure off of the top of the tank....... But make sure you have it outside and plenty of ventaltion and no open flame any where...... Propane is lighter than air so it settles down on the ground at the lowest point.....hope this helps..... Or you could take it back to your suppler and get a different tank.
Posted on Feb 01, 2011
Feb 28, 2015 | Reddy Heater-30-55,000 BTU Variable
Jan 23, 2010 | Reddy R60A Utility Heater
Fumes
WITH PROPANE THEY NEED CLEAN AIR, I HAVE THIS PROBLEM WHEN I USE THEM IN A CRAWL SPACE, TRY TO PUT IT SOME PLACE WHERE IT CAN GET CLEAN AIR, GOOD LUCK PLEASE LEAVE FEED BACK IF THIS WORKS
Jan 14, 2010 | Desa International Reddy Heater R40 40,000...
Heater will only work with top on. will not fire up with top on. when running with top off, will shut off when top is replaced
The fuel maybe contaminated,or you need some anti-gel additive to add to the fuel.Check the intake filter in the back,near the pump plate.
Jan 09, 2010 | Desa International Reddy Heater R40 40,000...
I can't get my reddy heater to light. No fuel
If there is NO fuel then the pump rotor is probably broken. http://www.reddyparts.com/rotor%20replacement.htm
If there is SOME fuel then set the air pump pressure. http://www.reddyparts.com/pressure.htm
Nov 02, 2009 | Desa International Reddy Heater R40 40,000...
Excel - Find the last, 2nd last and 3rd last data in a column
There isn't enough information to make a formuls for you. I normally just go to where I want to put my formula, hit the Auto-Sum button and modify it to suite what I want. Make sure you don't have formatting set for auto or turned off for the cells you want to work with.
Dec 29, 2008 | Reddy Heater-40,000 BTU Kerosene w/T'stat
Reddy Heater-30-55,000 BTU Variable Logo
67 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Fahr Quad
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
