Question about Boating
50hp blue band mercury .crack in plate port side leaking water
Mercury outboard motor 50hp 4cylinder 2stroke 1970?
Posted by doug hunt on
paul
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,190 Answers
If its got about 18 bolts on it and aprox 12by6 inch in size then thats the exhaust plate !
remove all bolts and remove plate and then a s/steel plate , check for corrosion and damage etc ! clean all gasket faces and replace gaskets and put a light film of gasket glue on all areas where gaskets touch and refit !
Posted on Apr 15, 2015
What might cause the warning system on mercury 50hp outboard to beep 3 times every 4 minute s
That is the engine default code. It has to do with the regulator not getting enough water to cool it down. Those are water cooled regulators not air cooled like cars. The impellers for the cooling system should be replaced about every 3-4 years. It may still cool the motor but not enough to cool the regulator which supplies the computer to set the trouble codes.
Jul 21, 2018 | Mercury Boating
50hp Mercury outboard electrical schematic
Hey David,
Yo should find all the info you need here..this will be very very helpful...' Mercury Outboard Manuals by Seloc 1965 2014
Jun 07, 2017 | Mercury Boating
How to find model number on mariner outboard 4hp 2stroke engine
Mariner 4hp are identical to Yamaha engines.
You should find a sticker on the port bracket with serial and model number.
If that sticker has disappeard, an aluminum piece is stamped in the side of the cilinder. The numbervstamped in that round pieceis the serial number. I can convert that serial number in a year/model number...
Feb 27, 2015 | Mercury Marine 4hp & 6hp Stroke Outboards...
What type oil does 1986 bayliner capri 50hp take
if its 50hp what outboard have you and what oil you changing ? 2stroke or 4stroke ?
Sep 11, 2014 | Boating
50hp mercury marine outboard
put a water pump kit in it
May 26, 2013 | Boating
I'm looking for a downloadable version of the service manual for this motor. Any Ideas? It's a 1994 mercury XRi 175 hp outboard
I couldnt find one anywhere for my merc 75hp 2stroke-ended up buying a service manual $70
Oct 09, 2009 | Boating
Need online repair manual for evinrude 50hp outboard
how can I adjust the shifting linkage on my 50hp evinrude. I have the cable adjusted all the way out but it will not go into reverse
May 10, 2009 | Boating
Boating Logo
157 people viewed this question
Top Boating Experts
ray gallant
Andrew Taylor
Andrew Taylor
Bill Boyd
Are you a Boating Expert? Answer questions, earn points and help others
