SOURCE: How to bridge two 15" kicker solo barics 2 ohm voice coil with a kicker zx750.1
put them in series.
SOURCE: speaker wiring
hi mat
you should have four terminals two plain and two with dots
to get the best power cut two inches off good speker wire
tear apart now place one wire from
plan black to red with white dot then
plain red to black with white dot
this is how set then up with my directed 1100d mono amp .. very loud at half gain
well hope this helps.............. ..benjaminsarmy..
SOURCE: Where can I buy a voice coil for a 15" kicker cvx
Do you have the technical capabilities and know how to be able to replace this voice coil? I am Not sure if you have ever tackled this type of problem. Otherwise you may not be asking where to locate a replacement at. Good luck in your search.
A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Hi yeahonda,
Your Kicker L7 Ohms may be too low for the MA Audio Mono block amp. The MA Audio Amp is probably 2 Ohm Stable. The kicker will either be 2 ohm or 4 ohm Dual voice coil. To eliminate the low ohms as a possible threat to causing the map to go into Protect, Wire the kicker Voice Coils in Series. This adds the ohms, so that you either have 4 or 8 ohms.
I am using the following codes to show wiring. VC1+ stands for the Kicker Subs Voice Coil #1 Postive post. AO+ is the MA audio Amp output positive.
AO+ to VC1+
VC1- to VC2+
VC2- to AO-
This shopuld give you 4 or 8 ohm depending on the 15" L7 setup. Crutchfield does not carry the Kicker L7 in 15" They do have the L5 in 15".
If you know how to read a Volt Ohm Meter, set it to OHMs 20 and measure across VC1+ to VC1- and you should see between 1.5 and 5 ohms.. Do the Same with VC2+ to VC2-. you should see the same voltage. Also read from the Voice coil metal housing to VC1+ , VC1-, VC2+, and VC2-. and you should not read any ohmage to the case. The meter should say OL, or -1.
Good luck.
