I turned off my iphone and i do have fingerprint pass but it says i have to put my passcode first..but i forgot it.
SOURCE: I forgot my passcode to unlock my iphone
It depends on the severity and the settings you have given the iPhone and whether you have the computer that you synced your iPhone with... Here's the full explanation. I would recommend reading the second paragraph first, but the solution if you really forgot your password is in the first paragraph.
==If you have the computer you synced your iPhone with==
If you cannot remember the passcode, you will need to restore your device on the computer that was used to originally sync the iPhone or iPod touch so that you can reset your passcode and resync the data from the device (or restore from a backup). If you restore on a different computer that was never synced to the iPhone or iPod touch, you will be able to unlock the device for use and remove the passcode but your data will not be present. Refer to "Updating and restoring iPhone and iPod touch software."
"If you enter the wrong passcode too many times, you'll see a message that says "iPhone is disabled" and to try again later. If you repeatedly enter the wrong passcode, iPhone or iPod touch will be disabled for longer intervals, before you can try again. After too many unsuccessful attempts, you won't be able to try again until you connect to the computer you normally sync with. Note that starting with iPhone 2.1 software, there is a setting to cause the device to erase itself after 10 consecutive incorrect password attempts. This setting is off by default. It can be turned on by tapping Settings > General > Passcode Lock after you enter a correct passcode."
The full article can be found here: http://support.apple.com/kb/HT1212
==If you don't have the computer you synced your iPhone with==
If you don't have the original computer the iPhone synced with, the only solution is to force your iPod Touch into recovery mode and then restore it. You will lost all the data on the iPod Touch, but after this method is done, everything will work. You can find the steps to solving this problem here:
http://support.apple.com/kb/HT1808?viewlocale=en_US
SOURCE: i forgot my passcode and now my iphone is disabled.....
how do i find out what my passcode is
SOURCE: i forgot my apple iphone
Try the Restore procedure from iTunes If you have problems. But first try the recovery procedure.
1.
Disconnect your iPhone cable but leave connected the other USB end to the computer.
2.
Turn
off your iPhone holding the Sleep/Wake button. The red slider bar
appears. Slide the bar and wait until the iPhone turns off. Or you could
hold the Sleep/Wake and Home buttons at the same time until the iPhone
turns off.
3.
While pressing and holding the Home button
connect the USB cable to your iPhone. It should power on. Hold the Home
button until you see the "Connect to iTunes" message. Open iTunes if
necessary. You should see the "iTunes detected an iPhone in recovery
mode..." alert screen.
Choose " Restore"
SOURCE: iphone new passcode I forgot my passcode
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
SOURCE: Iphone disabled, can't connect to itunes
read detailed solutions on "forgot iPhone passcode and iPhone disabled" from http://goo.gl/z5CNo
