Amana DLE330RAW Electric Dryer Logo
A
Anonymous Posted on Feb 28, 2015
I have and Amana electric dryer when I push the start button it buzzes and does not start
When I push the start button on my dryer it buzzes like it does when the dryer is done drying and it doesn't start up
gbob59
Level 3:
  • Amana Master 3,063 Answers
  • Posted on Feb 28, 2015
gbob59
Amana Master
Level 3:
Answers
3063
Questions
Helped
705794
Points
10419
Wild guess the dryer is overloaded, Or too hot and needs to cool down. There are temp sensors that will prevent starting when too hot. You may have drive belt or fan problems exhaust pipe clog.
Testimonial: "Dryer hasn't been used in a week so it can't be hot. The vent hose is not clogged and the belt is fine. Any other ideas?"
  • gbob59 Feb 28, 2015
    Im going to guess that the High Temp cut out switch has become disconnected or is bad. That symptom would be the same as the "too hot" issue. You probably need to call service. Ask them how much. They may find other problems. But at very long distance that's my best guess.
Amana electric dryer #NED5200TQ when i push star button all it does is make a buzzing noise no matter where the dial is
open door and turn drum clockwise by hand,listen for scraping"something hung in front or rear drum seal"close door and try start.if it still hums you may have a bad timer or motor ,or switch on motor.you may need to call for service on this one
1helpful
Amana dryer mod. ned5100tq1 will not start. It only buzzes when i push the start button
Does it buzz or growl? Reach inside and turn the dryer by hand. Is the drum hard to turn? Might be a bad roller or possibly something stuck in the filter chute and lodged against the blower. I worked on a dryer exactly like yours and made a video. If the blower is clean and clear of obstacles and the wheels are fine then the motor needs to be replaced which is easy to do. The hardest part is getting the blower wheel off the motor (backward threads on it) Motor replacement video:
Manual and more is on my BLOG PAGE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
When i push start my dryer buzzes at me
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
3helpful
2answers
I have an amana dryer that i bought used. The start button buzz's when pushed, but the dryer does not start. I haven't gotten into it just yet, but i will be able to test with a multi meter, whats first to...
try to turn the drum while you push the start button and hold the door switch in. it might start running that way.,
if it does start running, then you have a sticking motor switch and you will have to replace the entire motor.
it happens alot and try turning it first then if it happens again you might want to replace the dryer because of the cost of a new motor.
Have AMANA dryer ALE230RAW. Hear buzz when start
I also have this problem, but it is after the dryer has been running. When the motor is hot, it buzzes and will not run. Sometimes it will run if I turn the drum or take some clothes out. I disassembled the dryer and cleaned the motor of lint. This helped but not completely solved the issue. I have completely removed the motor and will thoroughly clean the motor (stator and brushes) and will try again.
4helpful
2answers
Whirlpool LER 5436 tumble drier- loud buzz
When start button is pushed there is a buzzing noise but dryer will not start.
1helpful
When I push the timer button to start the dryer it just buzzes.
verify connections on motor. sounds like the start relay has gone out on the motor. if it was your push to start button it wouldn't make any noise.
2answers
Amana gas dryer wont start. just makes a faint buzzing noise
The drive motor starting capacitor is likely dead. This can be tested if you are competent enough to take the thing apart and use an electronic multimeter. Otherwise it is a cheap part to replace, depending on how much the repair guy charges for labor and to be called out.
2answers
Dryer work turn on, buzzes when start is pushed
It may be just your timer switch. Look at all the wiring first. The receptacle to the plug, cord and into the back of the dryer.
Top Amana Dryers Experts
Kolbrun...
Virgil Watts
Are you an Amana Dryer Expert? Answer questions, earn points and help others
