Question about Bunn 10 Cup Home Coffee Brewer
How to activate a 10 cup bunn coffee brewer model nhb?
Bill Chestnut
    Scholar:
  • 155 Answers
I don't understand the question, but here is a try.
1 - put in two pots of water.
2 - put in third pot, the water should start coming out
Allow the water to heat (thirty minutes) then put coffee in filter housing, put in one pot of water, put empty pot on warmer, close lid, wait for brew cycle, enjoy coffee.
Posted on Mar 07, 2015
  • Arthur Snow
    Arthur Snow Dec 25, 2015
    Thank you
  • Arthur Snow
    That worked my wife thanks you very much
How do I fix a leaking Bunn Coffeemaker model NHBX-B?
This is a home model pour over. Overfilling is the most common cause of leakage as there is no plumbed in water line. You should only pour in the amount indicated on the decanter. If it is overflowing, check if you have the right decanter as someone may have used an old pot from a larger brewer. Say there was a 12 cup pot around and now you have a 10 cup brewer.
* carefully pour water to the inner fill line. You will probably see a ledge or spill off hole on the inside of the fill tank. Some units will spill out the back, others may spill back into the drip funnel. Note at what point you get near the spill level and note how much is left in the decanter. The amount left is your over flow.
* If you want more accuracy then use a measuring cup and count how many cups are needed to fill the brewer.
* Unplug any brewer that has water coming from the base. Dry up the area and drain the brewer. Dry off and let sit to completely dry out. Refill, note any leaks? If okay then plug in and brew as normal.
* still having problems? Contact your vendor for service.,
Aloha, ukeboy57
Jun 30, 2015 | Bunn NHB Coffee Maker
How do I set up my new 10 cup Bunn velocity brewer to brew only 4 cups?
To do that it is a good idea to put water for four cups and four coffee spoons of coffee. Kolbrun
Oct 04, 2014 | Bunn NHB Coffee Maker
Bunn NHB model leaks water out of the bottom
Please call customer service at 800-352-2866 with the date code from the bottom of your brewer. We will be happy to assist you with this issue.
Dec 31, 2010 | Bunn NHB Coffee Maker
How do you clean the Bunn 10 cup classic comercial coffee maker it is a BX-B model?
To clean your brewer, with the machine still turned on, pour in 1 qt of white vinegar and let it sit in your brewer for 2 hours. At the end of 2 hours, you will flush it out with 8-10 decanters of water.
Dec 26, 2010 | Bunn 10 Cup Home Coffee Brewer
My bunn coffee msaker isd about two months old and it now will not allow the water to pass to the filter, oly about a cups worth came through
If you will call Customer Service, either a new brewer will be sent to you with return shipping label to return the defective brewer or troubleshooting can be done to determine and correct the problem.
May 05, 2010 | Bunn NHB Coffee Maker
My Bunn coffeemaker NHB is leaking from the bottom onto my counter. Can this be fixed?
If you will call Customer Service with your Model and Date Code located on the bottom of the brewer, we can assist you with this problem.
Apr 28, 2010 | Bunn NHB Coffee Maker
Bunn ModleNHB
There is an electrical problem with your brewer. If you will locate the model and date code on the bottom of the brewer and then contact customer service, we will be able to assist you with resolving this problem.
Mar 30, 2010 | Bunn NHB Coffee Maker
Bunn 10 cup home coffee maker
It sounds like a seal/gasket is defective causing it to leak. Please locate the model and date code on the bottom of the brewer and contact customer service for troubleshooting and replacement options.
Feb 05, 2010 | Bunn 10 Cup Home Coffee Brewer
Hi: My Bunn coffee maker started leaking. Can this be fixed. he Model is NHB and date code is 145105. My address is: Tom Allen 3800 South Garrison Chapel Road Bloomington, Indiana 47403 PH...
Tom, your machine is out of warranty but we can offer a replacement brewer for $68.43. In order to do this, please send in a check or money order with your brewer to the following address:
Bunn Corp
900 E Townline Rd
Creston, IA 50801
Please include a note with the machine with your. name, address, and phone number.
Oct 19, 2008 | Bunn NHB Coffee Maker
Bunn 10 Cup Home Coffee Brewer Logo
204 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
