When is spin cycle spin drain and spin Making very loud noises
SOURCE: Kenmore 80 series 110 washer making loud noise during final spin
Make sure all springs are still in their place tilt the machine back and look under it and you can see them. 2nd all legs must be level as well as the floor.
SOURCE: spin cycle not working, was making loud noises,water won't drain
i dont have a model number ..just tip unit prop it up try and spin unit with belt on with your hand ,,than take belt off and spin pump pully..by itself...onthejob
SOURCE: Washer won't spin- flashing "f 02"
in the HE3 series it means the drain tube or pump is clogged
SOURCE: My Kenmore Elite 3T washer
Hi.
When that happens it is often because the drum bearing is starting to go. The first symptom is a loud high pitched noise during the spin part of the cycle. As problem gets worsening you will notice that the drum will be a bit wobbly if you spin it by hand.
Here parts and diagrams.
Regards.
Ginko.
If the washer is roaring during spin, the bearings are bad and you will need to replace the outer tub assembly.
Here is the part to order.
The part comes with a 365 day, any part, any reason return.
