Question about Kenmore HE2 Plus Front Load Washer
Dl f error code kenmore 11045081400 washer. what does it mean?
Jeff Armer
  • 15,575 Answers
Here is a youtube video , you code has to do with door lock assembly ! Troubleshooting and Repairing an dL Error Code on Whirlpool Duet Washer . your washer is the same as this . Kenmore is built by whirlpool !
Posted on Feb 27, 2015
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
Machine keep flashing dl and that keeps the door from locking
Error code DL means door lock failure. Best off to call a certified repair company such as Sears.
Mar 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Door is locked dL error code
DL error code means the door is locked. The door lock mechanism may need to be replaced. I would not recommend attempting this on your own I suggest you call a service tech.
Mar 17, 2010 | Kenmore Elite 45986 Front Load Washer
What does code FDL mean? kenmore elite wash maching
You are getting and error code F-DL which means the main control board is sensing that the door is not locking. Most likely a problem with the door lock/latch assembly.
Feb 02, 2010 | Kenmore 45981 Washer
Error message of f dl on kenmore washer model he 4t
does your washer stop on spin cycle some time. your is 4/5 years old?. f dl means door lock system is bad but i don't think so. do you have other error code beside f dl if yes then i think your washer need new main control board.
May 24, 2009 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Error code DL...
DL indicated a door lock failure. it will flash DL, then a F followed by a number (80, 82, 84, 85)
Jan 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
What do i do when it says dl?
usually when it is clicking when it fails and gives you an f11 error code. This means you have a fauly ccu board. it is a communication error between the computer and the door lock. I am 99% possitive you need a new controller.
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Error codes
if that is a kenmore or whirlpool after checking all hoses and screens and cleaning pump suspect the flowmeter ..remove top small round thing left side with 2 small hoses attached also possible water level switch on right side but still most likely flow meter
Nov 14, 2008 | Washing Machines
Error code
If you see "dl" or "du" error codes, these are usually indications of a failed door latch assembly and will require replacement. You can click on the following link if you need step-by-step instructions on how to replace the door latch:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
Hope this helps!
Thank you for contacting us at FIXYA.com
Jun 06, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Kenmore HE2 Plus Front Load Washer Logo
610 people viewed this question
Michael Thomas
Michael Thomas
Paul Carew
Nicola Conroy
