Soundstorm SDVD-100 Car DVD Player Logo
Posted on Jul 08, 2009
My sdvd-100 keeps ejecting the disk, any disk.
My new SDVD 1332 will not play all dvd disks
Take it back to the SONY STORE, and exercise the WARRANTY to get it replaced. Take one of the "bad" DVD disks along with you, to demonstrate the problem.
I need a manual and remote for soundstorm dvd-100
the manual can be downloaded at a few places on the web, as for the remote that may be harder to find
user guide retrevo.com/support/Sound-Storm-SDVD100-Car-Videos-manual/id/23153ci461/t/2/
My hp laptop keeps ejecting disc itself when i insert any disc. Wat do i do pls
> keep ejecting
The disk-drive is having a mechanical problem, i.e., it is not fully-loading the disk,
or it is not detecting that the disk is fully-loaded. Therefore, it assumes that the open/close
mechanism is "jammed", and so it ejects, to indicate that the disk-loading was not completed.
Replace the disk-drive.
Forgot parental pass code.
With some decks you can get in using either an all 0 code or an all 9 code entered as the parental passcode.. have you disconnected it from the power supply and let it sit for a bit to see if you can clear the memory?
1helpful
Put a childs dvd in asking for parental code?
There is a factory preset parental code you need to enter (unless that default code was changed). That factory code is in your user manual. In order the enter the codem, you will need the remote (number pad). The remote can be ordered through Soundstorm for $35.00 and you can download the manual from their knowledge base, just search "SDVD-100". Once you have both, just use the number pad on the remote to enter the factory parental code and the system will unlock.
Can not eject zip disk
I have the imoga 100 external zip drive and there's a pin hole on the front panel. that if you straighten a paper clip and stick in the whole, it should manually eject the disk.
Nakamichi MB-100 Disk error
VERY COMMON PROBLEM
THE BEST THING TO DO IS THROW IT AWAY
Soundstorm sdvd 900 problem
i have a sdvd-900 and a sdvd-300m
and i donot have the remote control how do i get it
6helpful
Soundstorm car dvd player
This is from the soundstorm website: If your DVD player shows a "Parental Code" on the screen. Here is the factory default code. It is 3308. Once you have this code, you can go into the settings and change the level to whichever level you like. Here is a break down of the levels: Level 1 = G Rated Level 3 = PG Rated Level 4 = PG 13 Rated Level 6 = PG-R Rated Level 7 = NC-17 Level 8 = Adult Level 0 = No Parental
250 zip drive
Throw it away. It is rubbish.
Top Soundstorm Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Soundstorm Car Audio and Video Expert? Answer questions, earn points and help others
