Question about NEC Dterm DTP-2DT-1 Phone
SOURCE: Nec DTerm Series i - Feature Light Flashing URGENT
Thankfully I have found a solution that has worked.
A 'winking' (flashing) feature button indicates the station is in call forward - all calls mode.
To cancel this setting do the following
Lift the handset or press speaker
Dial the access code 4 + 2 (set as default)
Receive confirmation tone and restore handset or press speaker
I have found the manual at the following link to be the best resrouce ever - very easy to understand
http://www.nec.co.th/html/download/Manual/Features%20&%20Specifications.pdf
Posted on Jul 08, 2008
SOURCE: NEC dterm series II phones-name desplay
This works on the series E phones. It may or may not work on the series II.
Pressing the TRANSFER key will change the current letter to lower case.
Example to enter the name “Pat” press:
77 HOLD 22 TRANSFER HOLD 88 TRANSFER HOLD
Posted on Sep 23, 2008
SOURCE: NEC Dterm 80 calls won't go to voice mail
for us i just found this out.
1.Fwd B/NA
2.1 - 1:set-0:cancel
4.200
5.speaker
after 4 rings it goes to voicemail
this works for us.
i hope it works for others too.
turn this feature off
1.hit fwd b/na
2.0:cancel
3.exit
4.exit
should see the normal display then.
Posted on Jan 16, 2009
SOURCE: How do you disable DND on NEC Dterm 80 phone WITHOUT DND button
Feature 69 feature
Posted on Apr 01, 2009
Aug 27, 2012 | NEC Dterm DTP-2DT-1 Phone
Jun 20, 2012 | NEC Dterm Series I Dtr-8d-1 / 780039 Black...
Sep 04, 2009 | Lands Phones
Apr 14, 2009 | NEC Dterm DTP-2DT-1 Phone
Mar 01, 2009 | NEC Dterm DTP-2DT-1 Phone
Jul 17, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Jun 13, 2008 | NEC Dterm DTP 32D-1 Corded Phone
Jan 16, 2008 | NEC Dterm DTP 16D-1 Corded Phone
350 people viewed this question
