Drills Logo
Posted on Jul 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Battery charger not working - Drills
nathan
Level 3:
  • Master 634 Answers
  • Posted on Jul 08, 2009
nathan
Master
Level 3:
Answers
634
Questions
0
Helped
290062
Points
1974
Make and model would help, general help do you have voltage tester? if so look at charger and find voltage output, test contacts and if lower than listed charger has gone bad, also clean all contacts with pencil eraser to make sure they are clean on battery and gun, if charger is good and contacts clean either battery is bad test in another device or test voltage, if battery good the drill is bad
1helpful
My Eliminator Intelligent Battery Charger, now flashes 000 regardless of what battery I put it on. Can I reset it and get my charger working again?
you can try to reset your charger and get it working again:
Check the battery voltage: Use a voltmeter to check the voltage of your battery. If it's below 3 volts, it may be too low for the charger to detect. In this case, you may need to use a different charger or replace the battery.
Check the connections: Make sure that the battery terminals are clean and securely connected to the charger. Loose connections can cause voltage drops and prevent the charger from detecting the battery.
Check the fuse: If your charger has a fuse, check if it's blown. A blown fuse can prevent the charger from working properly.
Reset the charger: Unplug your charger from the power source and remove any connected batteries. Wait for 10 seconds and then plug it back in. This should reset your charger and clear any error codes.
If none of these steps work, you may need to contact customer support
tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 • Cameras
Got new batteries but chRger won't charge them
Battery CHARGERS must have the correct batteries (NiCd or NiMH), plugged into a working outlet, and the batteries much be in a specific position. IF 2 batteries are in a 4 battery charger, and they are both in the center, It won't work. If 2 batteries in a 4 battery charger on the left, it will work if they are both securely positioned.
Once in awhile you get a non-working charger. Make sure you have the right charger with batteries. A few have a switch for NiCd or NIMH.
Jun 03, 2016 • Golf
1helpful
What volt charger do i need to charg mower 12volt battery?
Doug, Any 12 volt automotive charger will work for your lawn tractor, the cheaper no frills chargers will work fine.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Battery Chargers Canadian Tire
Amazon com Battery Chargers Jump Starters Battery Chargers Portable Power...
Car Battery Chargers
12v battery charge doesn't work in car
A few reasons why the charger is not charging the battery: The charger itself is not working; The battery will not take a charge, the battery can be 'dead'. If you can, connect the charger to another battery, just to see if it is working. The charge indicator needle will move. If you have confirmed that the charger is working, then the battery may be beyond charging. Make sure the connections from the charger to the battery terminals are tight.
Napa charger #85-435 will not charge
He said his battery charger is not working, this has nothing to do with the car not starting or charging? So if anyone can recomend what he needs to do to get his battery charger working would be helpful to him.
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 • Cell Phones
5helpful
Battery charger on green light when battery flat ,it should be on red also when charger plugged into bike, bike works ok when you take charger out bike stops working
If your bike works when you have the charger connected but doesn't whith the charger disconnected and just the battery then your battery is not charged or you have a bad connection between the battery and ebike.
If the battery charger is showing green then it normally means that charging has stopped charging and there is no current flow to battery. This could be because the battery is fully charged, OR there is an open circuit (broken wire, etc.) between the charger and battery, OR your battery is so flat the voltage is below the low voltage cut-off point of the charger so the charger is not switching on.
You need to check the voltage out of your battery and compare it to the LVC of your charger (should be specified in the user manual), but from what you have described I'd say you need to replace your battery.
1helpful
I have a Makita with 2 PA14 batteries and a DC1414F charger. When I turn the charger one the green light flashes once but no other lights show at all when I'm trying to charge my 2 batteries. Neither...
You stated you have a 12V Cordless Drill with PA14 batteries. The PA14 battery is 14.4V. The battery may fit in your tool and might work for a while but the motor isn't made for that battery. The way to check the batteries is to try them in another charger, any 14.4V to 18V pod/stick charger will work. The way to check the charger is to try another battery, any good 7.2v to 14.4V pod/stick battery will work. Unless the charger got wet or extremely hot the problem is usually the battery. Just check to make your tool and battery voltage is compatable.
Top Drills Experts
ADMIN Andrew
ADMIN Andrew
john h
Steve Pack
Steve Pack
Are you a Drill Expert? Answer questions, earn points and help others
