Question about Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch
Where is the reset button on a hottpoint side by side refrigerator.
Ken Wieczorek
    Sergeant:
  • Hotpoint Expert
  • 451 Answers
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all 4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
To perform a self diagnostic test, locate the test in Table 2, Diagnostic Tests.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test. Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. The temperature control panel is reset automatically.
• Unplug the refrigerator for at least 10 seconds. Test mode will terminate when the refrigerator is plugged back in.
Test mode will terminate automatically after 15 minutes of inactivity.
Read more: http://appliancejunk.com/forums/index.php?topic=10408.0#ixzz3VIqUINVz
Posted on Mar 24, 2015
Does refrigerator have a reset button
Usually not but it does have a self resetting device called a klixon to protect the compressor from an overload
Sep 29, 2014 | Sub-Zero Overlay Design 632/O Side-By-Side...
How do i reset the filter light on my refrigerator msd278ge
Simply press and hold the dispenser lock and auto light buttons on the dispenser (at the same time) for four (4) seconds until the filter status indicator begins to flash, then release the buttons. On some Amana refrigerators, you need to press the dispenser lock and water buttons for four (4) seconds until the filter status indicator begins to flash, then release the buttons.
Also note that
  • Remove the old water filter from your refrigerator by turning the handle counterclockwise and pulling it out of the filter holder. The filter is located in the upper right corner of the refrigerator.
  • Step 2Slide the replacement filter into the filter holder and turn it clockwise.
  • Step 3Press and hold the "Reset Filter" button until the indicator lights go off if your model refrigerator has a "Reset Filter" button on the control panel.
  • Step 4Hold the "Lock" and "Light" buttons on the control panel until the filter indicator lights turn off if your model refrigerator does not have a "Reset Filter" button. For models that do not have a "Light" button, press and hold the "Lock" and "Water" buttons.
  • Good luck......
    Jul 29, 2010 | Maytag MSD2758GEB Side by Side...
    Have replaced the water filter - how do i reset/turn off the "change filter" light ?
  • Step 4 Hold the "Lock" and "Light" buttons on the control panel until the filter indicator lights turn off if your model refrigerator does not have a "Reset Filter" button. For models that do not have a "Light" button, press and hold the "Lock" and "Water" buttons.
  • May 18, 2010 | Maytag MZD2766GES Side by Side...
    LG side by side buttons don't work
    Reset the unit to its initial status by unplugging the unit for about 15 minutes. It will allow the MICOM IC for both the main board and display PCB assembly to reset itself.
    If this doesn't resolve the issue, you need to have it checked by a qualified technician to prevent further damage or issue to happen in the future. A test mode is necessary to properly diagnose the problem.
    Nov 25, 2009 | LG LSC26905TT Side by Side Refrigerator
    Reset button
    There are no reset buttons, try unplugging and leaving it unplugged for 10 minutes or so, if it doesn't start working again you may need a new control board
    Jun 14, 2009 | Frigidaire FSC23F7D Side by Side...
    How to reset filter sensor?
    youll nned to physically reset the button, usually holdingdown for 3 secs, repaclin ghte filter itself will not reset the counter
    Jan 20, 2009 | KitchenAid KSRG25FK Side by Side...
    Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Logo
    Top Hotpoint Refrigerators Experts
    Dan Webster
    Dan Webster
    jdthefixer
    Michael Thomas
    Michael Thomas
    Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
