Question about Sony Network Walkman NW-E005 MP3 Player
MP3 player dead
I hadn't used my Sony NW-E005 player for a few weeks. Today I plugged it into my computer's USB port and...nothing. It's just dead, doesn't charge up at all! Any ideas as to what may have caused this?
PS: I have never used the Sony sonicstage bloatware, always Dr Void's wonderful voidmp3fm
Posted by groobert on
  • simspap Jan 20, 2008
    The same problem occured when I fully discharged the NW-E005 because it was open in my bag.
    I tried to reset it but still nothing happens.
    I am afraid the batterie has broken down.
  • Anonymous Nov 11, 2008
    as above!
Anonymous
Gee - why didn'ti thik of that!!
Posted on Nov 11, 2008
ruden gal
First ting u should probably do is go and talk to the people tht u first brought the player from and see if u they could anyting out before it gets more worser than it already is...
Posted on Nov 13, 2007
1 Related Answer
Anonymous
  • 8 Answers
SOURCE: MP3 player dead
well did you push the it all the way in the USB Port? Sometiems I don't connect it all the way and it doesn't charge. I go to my school and charge it on there computers too and it charges fine.
Another advice is to actually use the Sonicstage to avoid viruses. It's not that hard to install or download music files.
Posted on Dec 15, 2007
When plug in windows does not recognize usb used to work ok
What did you do before this problem started?
I am assuming that you have tried a different USB port, if that doesnt work a different computer?
Aug 24, 2010 | Sony Network Walkman NW-E005 MP3 Player
My walkman mp3 player wont turn on!! how do i get it to turn on? it hasn't gotten wet or anything and i cat think of any reason why it shouldnt be working
When you plug it into the USB port of your computer does it do anything? If it doesn't then your player is likely dead. If it does do something then it likely just needs a full recharge.
Jul 26, 2009 | Sony Network Walkman NW-E005 MP3 Player
How can i down load music from computer to sony
plug the usb cable from pc to your player then download your mp3 file. you can use copy and paste also. copy the file from pc and paste to your player.
Apr 01, 2009 | Sony Network Walkman NW-E005 MP3 Player
How to diassemble Sony Network Walkman NW E005 2 GB MP3 Player
these units aren't meant for disassembly only for replacement.
Mar 30, 2009 | Sony Network Walkman NW-E005 MP3 Player
Battery Problems?
Hi all. If you have had your players for some time, and have re-charged them many times over that period (a usual action) then your battery might be near dead.
Most re-chargeable batteries, the longer they are used and re-charged, actually decrease in charged capacity over time.
The only solution, if this *is* the problem, is to fit a new battery. Firms make replacement nw-a3000 etc. batteries for this purpose. I did a google search and found this site:
http://www.batteryupgrade.com/product_detail.php?productId=82781017
There are, I am sure, many more sites which can supply you with what you need!
Jul 30, 2008 | Sony NW-A1000 MP3 Player
Sony mp3 player nw-e005
It sounds to be a false contact problem. If when you connect it the player shows the battery as it will start charging it, then I bet it is a false contact caused for normal use of plugging/unplugging in USB port. If this is the case, I would try to fix it before getting a new one.
May 17, 2008 | Sony Network Walkman NW-E005 MP3 Player
Files will not load
Try reformatting the drive to factory defaults. I would also try this unit on other PCs to verify that the USB port will not work correctly. Does the USB port on your Sony Walkman MP3 player have any damage or broken pins/connectors on the USB port?
Mar 31, 2008 | Sony Network Walkman NW-E005 MP3 Player
Sony walkmannw-e005
if your Sony mp3 player like my Sony has a file on it with instructions, just need to plug it into your usb and read the instructions
he this helps
Pepe
Feb 27, 2008 | Sony Network Walkman NW-E005 MP3 Player
MP3 player dead
Dec 14, 2007 | Sony NW-E002 MP3 Player
Sony Network Walkman NW-E005 MP3 Player Logo
Top Sony Audio Players & Recorders Experts
aliasger yq
Alvin Barnabas
Alvin Barnabas
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
