SOURCE: I have a Rheem EcoSense hot water heater and all
Have you try to reset the power to the heater?Then turn the hot water facuet on to see if it will start up.
SOURCE: burner will not stay lit turns off immediatly no
1/overheat stat 2/fan 3/micro switch, best of luck.
SOURCE: rheem gas tankless water heater with error code c4 13
problem is inside burner compartment o2 sensor dirty or block..need to have a qualify technician clean it.
SOURCE: Rheem tankless rtg 74pvn - heater hot water shuts
This is something you will have to contact rheem about due to the fact you don't have a fault code
SOURCE: Tankless water heater stopped working.
if you dont get any code then it is the circuit board..you will need to contact rheem or have a qualified technician check it
